Community Member
6500 (7600-SIP-200/400)
Is it possible to use a 7600-SIP-200/400 on a 6500 switch? I want to configure QoS (CBWFQ, WRED, LFI, LLQ) on this box. I tried using the GigEthernet but it could not accept my policy when i tried to apply it on the physical and virtual (Vlan) interface. Is there a way I can realize this goal.
I tried to insert the SIP-200 on slot 7 but I got this errors message when it boot.
*Sep 15 09:18:42.375: %C6KPWR-SP-4-UNSUPPORTED: unsupported module in slot 7, power not allowed: The image for the card is not bundled in image.
*Sep 15 09:19:04.319: %OIR-6-REMCARD: Card removed from slot 7, interfaces disabled
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 6500 (7600-SIP-200/400)
Which IOS are you using ? Must be 7600 WAN image.
Community Member
My ios: s72033-adventerprisek9-mz.122-33.SXI.bin.
It can only work on a 7600 wan image, only that image?
Yes, as mentioned above.
354
