Community Member
6500 shutting down
I have a 6500 with a SUP32. I am expecting delivery of a high speed fan tray and power supplies within a few days. However I need to upgrade from hybrid to native mode IOS before then. My system keeps shutting down on me with the following message:
2008 Aug 08 09:42:51 %SYS-0-FAN_SYSTEMSHUTDOWNSCHEDULED:System shutdown scheduled in 0 min, fan tray version incompatible
Again the system is running in hybrid mode. Is there any way I can reset the shut down time to say 30 mins so I can push ahead with the upgrade?
Any help rated
Gavin
1 REPLY
Hall of Fame Super Blue
Re: 6500 shutting down
Gavin
You can try this although personally i haven't tried it
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/system/messages/emsg.html#wp1016348
although i would strongly recommend you wait for your power supplies/fan tray. The last thing you want is to be in the middle of your upgrade and the switch reboots. You could end up spending more time fixing this than you would have spent waiting on your new parts.
Jon
262
