Community Member
6500 Switch + 2800 Router
Dear Friends
I have cisco router 2800, and I configure the fa0/1 interface with IP address 172.16.5.130/29 and from the Core Switch 6500 I configure the Gig interface with IP 172.16.5.132/29 as point to point connection but I cant ping any from both side
And the interfaces Up, also I try to configure default route but is not working
Please advice.
Community Member
Re: 6500 Switch + 2800 Router
Check the speed/duplex settings on both devices. for more info : http://www.cisco.com/warp/public/473/46.html
Community Member
I checked that already
Super Bronze
/29 but configured point-to-point, and Ethernet?
Can the devices ping each other on the /29?
Community Member
Thank you all. I asked my boss to change to /29 but what we can do>>>> he said no benefite.
Thanks All ..... This is the managers
Community Member
Inside 6500 can you ping 172.16.5.132 ?
Did you configure speed as auto?
Check your physical layer.
Community Member
the interface need to enable with no shut command
Community Member
Is the link protocol up in router?
155
