6504 enter in ROMMON mode - nothing helps !??!
Have this 6504, which after some power issues on the site, it boots in rommon mode, all the time and comes with crashinfo.
First, I was looking on the output I got, and then search on the error messages from that output, and that indicated on faulty supervisor. So I sent the supervisor (right module) to the remote site. After the supervisor has been insterted in the 6504, it is still comming up in rommon mode.
Have tried to issue boot coomand, reset, when i use "show bootdisk:" command, it says invalid filesystem, or syntax error. I  even tried to issue confeg 0x2142 from rommon mode and then reset, then it still returns in rommon mode. It it limited how much troubleshooting I can do from rommon mode. And always there is a crashinfo generated.
Anyone familiar with this, seen this before, or simply knows exactly what ii is :-) ?
Thanks you
Here is the output from the crashinfo :
--------- show ipc status --------
                            IPC System Status
 Time last IPC stat cleared : never
 This processor is the IPC master server.
 Do not drop output of IPC frames for test purposes.
 6000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
 Total Frames                                                2           4
 Total from Local Ports                                      1           2
 Total Protocol Control Frames                               1           1
 Total Frames Dropped                                        0           0
                             Service Usage
 Total via Unreliable Connection-Less Service                0           0
 Total via Unreliable Sequenced Connection-Less Svc          0           0
 Total via Reliable Connection-Oriented Service              1           1
                      IPC Protocol Version 0
 Total Acknowledgements                                      1           1
 Total Negative Acknowledgements                             0           0
                             Device Drivers
 Total via Local Driver                                      2           2
 Total via Platform Driver                                   0           0
 Total Frames Dropped by Platform Drivers                    0           0
 Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
 Re-Transmission                                                         0
 Re-Tx Timeout                                                           0
          Rx Errors                              Tx Errors
 Unsupp IPC Proto Version          0  Tx Session Error                  0
 Corrupt Frame                     0  Tx Seat Error                     0
 Duplicate Frame                   0  Destination Unreachable           0
 Rel Out-of-Seq Frame              0  Unrel Out-of-Seq Frame            0
 Dest Port does Not Exist          0  Tx Driver Failed                  0
 Rx IPC Msg Alloc Failed           0  Rx IPC Frag Dropped               0
 Rx IPC Transform Errors           0  Tx IPC Transform Errors           0
 Unable to Deliver Msg             0  Tx Test Drop                      0
 Ctrl Frm Alloc Failed             0  Rx Msg Callback Hog               0
          Buffer Errors                          Misc Errors
 IPC Msg Alloc                     0  IPC Open Port                   603
 Emer IPC Msg Alloc                0  No HWQ                            0
 IPC Frame PakType Alloc           0  Hardware Error                    0
 IPC Frame MemD Alloc              0  Invalid Messages                  0
                                      IPC Fragment Errors               0
          Tx Driver Errors
 No Transport                      0
 MTU Failure                       0
 Dest does not Exist               0
--------- show ipc rpc --------
                    IPC RPC Status
                                  Rx Side      Tx Side
 Total RPC requests                         0            0
 Total RPC replies                          0            0
                    IPC RPC Statistics
 Maximum RPC timeout(seconds)                          600
 Number of RPC timeouts crossed default max[  600]       0
                    IPC RPC Errors
 No Pending RPC Request for Received RPC Reply           0
--------- show ipc queue --------
There are 0 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use                     :         85
Message cache size                            :       6000
Maximum message cache usage                   :       6000
0  times message cache crossed      12000 [max]
Emergency messages currently in use           :          0
There are 85 messages currently reserved for reply msg.
--------- show ipc ports --------
There are 8 ports defined.
Port ID        Type       Name                    (current/peak/total)
   10000.1     unicast    IPC Master:Zone
   10000.2     unicast    IPC Master:Echo
   10000.3     unicast    IPC Master:Control
   10000.4     unicast    Card1/0:Request
     port_index = 0  seat_id = 0x10000    last sent = 0     last heard = 1
     rcv pending/peak/total       = 0/1/1
     seq-window size              = 128   number of messages in window = 0
     maximum out-of-seq received  = 0     maximum pending in window    = 0
     number of messages dropped   = 0     number of window resets      = 0
   10000.5     unicast    Card1:Request
   10000.6     unicast    Card1/0:Event
   10000.7     unicast    Card1/0:Exception
   10000.8     unicast    Rf_Proxy:Server:1
RPC packets: current/peak/total
--------- show ipc ports open --------
There is 1 port defined.
     port_index = 0 last sent = 1     last heard = 0
     xmt pending/peak/total       = 0/1/1
     Receiver seq-window size     = 128
--------- show eobc --------
Interface information:
        Interface EOBC0/0 (idb = 0x50A31490)
        Hardware is sb1250 EOBC
        Encap size         = 14         hardware status  = 0x210840
        IDB type           = 18         IDB state        = 4
        Encap type         = 0x1        Span encap size  = 0
        Error threshold    = 5000       Error count      = 0
        Error checking is enabled
Counters:
        rx_ring            = 0x440DB940 rx ring entries        = 512
        rx_head            = 0          rx_tail                = 0
        rx_count           = 0          rx_bytes               = 0
        rx rate (bits/sec) = 0          rx rate (packets/sec)  = 0
        rx_multicast_pkts  = 0          rx_bcast_pkts          = 0
        rx_good_pkts       = 0          rx_bad_pkts            = 0
        rx_buf_unavail     = 0          rx_fcs_err_pkts        = 0
        rx_runt_pkts       = 0          rx_oversize_pkts       = 0
        rx_pkts_len_err    = 0          rx_pkts_dropped        = 0
        rx_bad_pkts_dropped= 0          rx_bad_len_pkts_dropped= 0
        rx input drops     = 0
        rxr eobc shadow    = 0x440DD02C
        tx ring            = 0x440DB940 tx ring entries        = 0x200
        tx_head            = 2          tx_tail                = 2
        tx_good_pkts       = 2          tx_bad_pkts            = 0
        tx_bytes           = 128
        tx rate (bits/sec) = 0          tx rate (packets/sec)  = 0
        tx_late_coll       = 0          tx_excessive_coll      = 0
        tx_crc_err         = 0          tx_aborted_pkts        = 0
        tx total drops     = 0
--------- show ibc --------
Procyon tx counters:
  tx byte/packets 0/0
  0 tx late collisions, 0 excessive collisions
  0 tx aborts, 0 tx bad pkts, 0 tx oversize pkts
Procyon rx counters:
  rx byte/packets 0/0
  0 rx multicast, 0 rx broadcast
  0 rx bad pkts, 0 rx length errs, 0 rx code errs
  0 rx dribble errs
Procyon interrupt counters:
  0 ch0 pkts dropped, 0 ch1 pkts dropped
  0 rx underflows, 0 rx overflows
  0 tx underflows, 0 tx overflows
  0 tx late collisions, 0 excess collisions
 particles in free pool 512
procyon ibc stats:
   rcv particles = 0
   rcv packets = 0
   rcv ip packets = 0
   cef switched packets = 0
   fast switched packets = 0
   process switched packets = 0
   cef dropped packets = 0
   no particles = 0
   particles not replaced = 0
   zero length pak = 0
   giant packets = 0
   tx packets dropped = 0
   tx packets tx = 0
   packets dropped coz of no buffers = 0
   Interface throttle packet drops = 0
   inband input packet drops = 0
Interrupt throttling information:
   throttle activated 0 times
   throttle deactivated 0 times
   interrupt time slice 4000 usecs (1333333 ticks)
   process level time slice 800 usecs (266666 ticks)
   interrupt mask: 0000000900080000
   nested Throttling 0 times
--------- show scp status --------
Id Sap      Channel name    current/peak/retry/dropped/total  time(queue/process/ack)
0  0    SCP Unsolicited:0       0/    1/    0/      0/   62      0/   0/9064
1  20   SCP Unsolicited:20      0/    0/    0/      0/    0      0/   0/   0
2  2    SCP Unsolicited:2       0/    1/    0/      0/   61      0/   0/   0
--------- show scp process --------
Sap     Pid     Name
0       60      SCP Download Listen
2       79      slcp process
20      51      PF SCP process
22      3       Init
Total number of SAP registered = 4
--------- show heartbeat settings --------
heartbeat interval            = 2
heartbeat warning interval    = 30
heartbeat fatal count         = 5
heartbeat interrupt interval  = 30
heartbeat interrupt max       = 5
ignore rx                     = no
ignore tx                     = no
--------- show heartbeat --------
Out of buffers          = 0
EOBC tx failures        = 0
Negative clock updates  = 0
Fatal errors            = 0
Corrupted heartbeat msgs= 0
Last heartbeat sched    = 1012
Last heartbeat sent     = 307952
Scheduler history [PF_Init Process 0%/0% (00:05:07.156 0%/0%)] [PF_Init Process 00:00:00.824] [slcp process 00:00:00.828] [rf proxy sp agent 00:00:00.840]
 heartbt_pid=68  , pidname = Heartbeat Process
 Traceback of 68  :  408D1058 40BCC1EC 40889C74 40889C60
--------- show icc status --------
Class Name             Request Tx/Rx Msgs Pending  Max Pending       Total
    0 ICC                ALL    Tx             0            0           1
                         ALL    Rx             0            1           1
                           2    Rx             0            1           1
========= End of Crashinfo Collection ==========================================
File bootdisk:crashinfo_20140801-104205 Device Error :No such device
=== Flushing messages (10:42:05 UTC Fri Aug 1 2014) ===
Buffered messages:
Queued messages:
00:05:08: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:05:07: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:05:07: %PFREDUN-SP-4-AUTOBOOT: Disable autoboot for Supervisor in slot 1
00:05:07: %PFREDUN-SP-6-ACTIVE: Sup in slot 1 is crashing due to RP failed to boot
00:05:07: SP: Failed to send heartbeat poison message
00:05:08: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:05:08: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x4313fc04
  PC = 0x411d5efc, SP = 0x41d0a030, RA = 0x408dc0a0
  Cause Reg = 0x00001020, Status Reg = 0x34008002
rommon 4 >
175
