6509 Module Problem
Dear Gurus,
I inserted this modeul on our 6509 and here are the errors, whats the possible cause of these?
6509#*Feb 18 00:00:26.190 PHT: %OIR-SP-6-REMCARD: Card removed from slot 5, interface
s disabled
*Feb 18 00:00:37.341 PHT: %C6KPWR-SP-4-UNSUPPORTED: unsupported module in slot 5
, power not allowed: Unknown Card Type.
6509#
1     25651932 Aug 3 2007 11:10:58 +08:00 c6sup22-pk2o3sv-mz.121-20.E
#show module
Mod Ports Card Type                              Model              Serial No.
  1    2  Catalyst 6000 supervisor 2 (Active)    WS-X6K-S2U-MSFC2   SAD06020305
  3   16  SFM-capable 16 port 1000mb GBIC        WS-X6516-GBIC      SAD05510008
  5   48  unknown FRU type (major = 0x6003, mino WS-X6748-GE-TX     SAL08290NL3
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0001.6415.b77a to 0001.6415.b77b   3.2   6.1(4)       12.1(20)E    Ok
  3  0002.7ee1.37e0 to 0002.7ee1.37ef   3.0   6.1(3)       8.2(0.58)TFW Ok
  5  0011.926d.cd48 to 0011.926d.cd77   2.1   Unknown      Unknown      PwrDown
Mod Sub-Module                  Model           Serial           Hw     Status
  1 Policy Feature Card 2       WS-F6K-PFC2     SAD060201A7      3.0    Ok
  1 Cat6k MSFC 2 daughterboard  WS-F6K-MSFC2    SAD06020207      2.0    Ok
  5 unknown FRU type (major = 0 WS-F6700-CFC    SAD081405PU      2.0    PwrDown
Mod Online Diag Status
  1 Pass
  3 Pass
  5 Unknown
5 Replies 5
Marvin Rhoads
Your Sup II supervisor module is one that does not support the WS-X6748 module. See http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_bulletin0900aecd800f6e27.html which states, in part:
"Note: This module is supported only on the  Cisco Catalyst 6500 Series Supervisor Engine 720 running Cisco Catalyst  OS Version 8.1.2 or Cisco IOS® Software Release 12.2(17a)SX (available in the next few months) and  future software releases."
Lei Tian
WS-X6748-GE-TX  requires sup720. Please refer the link for modules and supported supervisor.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd801459a7.html
HTH,
Lei Tian
Reza Sharifi
Most likely that module is not supported with the Sup you have.
Have a look at this document for more info:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801b42bf.shtml#prob1ab
Reza
Giuseppe Larosa
Hello Jeff,
as explained by colleagues you cannot put a module 67xx on your chassis that has a sup2/MSFC2
there is no way for that linecard to talk with your sup2/MSFC2 as a result of this the module is powered down.
67xx expects to talk using switching fabric 720 Gbps that is present only on sup720.
to be noted sup720 has to be installed on slot 5 or 6 for this reason (the presence of the switching fabric)
Sup2 is installed in slots 1 or 2.
you can install CEF256 modules  if you install in slot5 a switching fabric version 2 the card is named SFM2.
Hope to help
Giuseppe
Clear now, thanks a lot.
