6509 sup fail
I hv 6509 with 720 two sup engine one is working fine but 2 sup l2 is working fine but msfc module is not.
what will be the problem for module 16 ?
Mod Slot Ports Module-Type Model Sub Status
1 1 48 10/100BaseTX Ethernet WS-X6148-RJ-45 no ok
5 5 2 1000BaseX Supervisor WS-SUP720-BASE yes ok
15 5 1 Multilayer Switch Feature WS-SUP720 no ok
6 6 2 1000BaseX Supervisor WS-SUP720-BASE yes standby
1 ACCEPTED SOLUTION
Re: 6509 sup fail
Hi Moorthy,
I am sure the msfc is either is rommon or in booting loop.
Console into the active spervisor engine and run the command " switch console 16 " to access the msfc in slot 16 via console and then check if it is rommon or booting loop and if it is neither in rommon nor in booting loop and even switch console 16 does not take you to msfc could be it is a bad hardware.
If it is rommon check with dir bootfash: if it has the right image to boot or not and if it has the right image does it has the right boot path or not.
If it in booting loop break the loop via ctrk + break key and then follw the same procedure.
Ankur
Re: 6509 sup fail
Hi Moorthy,
Ankur
Re: 6509 sup fail
Thanks for information & support Problem is solved.
regards,
190
