ar
7200 NPE-G1 Built -in GE interface LLQ Problem
Hi Guys.
I   am trying to attach an LLQ policy to my 7200 Gigabit Ethernet   sub-interface. I cant seem to attach the policy and giving me an  error.
Im using NPE-G1  GE interface:
Im getting the error below:
(config-subif)#service-policy output  8M
user-defined classes with queueing features are not allowed in a service-policy at sub-interface/pvc
in conjunction with session based queueing policy
policy-map 8M
  class class-default
    shape average 8000000
   service-policy QOS
policy-map QOS
  class VOICE
    priority percent 60
  class  NET-MGMT
    bandwidth remaining percent 5
  class MISSION-CRITICAL
    bandwidth remaining percent 20
But I can apply this policy on a different sub-interface.
Weird problem.
Need your input.
thanks
please show the running configuration for the main interface and a subif.
ar
Re: 7200 NPE-G1 Built -in GE interface LLQ Problem
Main interface:
scription Nextep Interconnect 10M [SL01316W]
mtu 1600
bandwidth 10000
no ip address
load-interval 30
media-type rj45
speed auto
duplex auto
no negotiation auto
interface GigabitEthernet0/2
mtu 1600
bandwidth 10000
no ip address
load-interval 30
media-type rj45
speed auto
duplex auto
no negotiation auto
Target sub-interface facing LAC which has an error:
interface GigabitEthernet0/2.1500
bandwidth 8000
encapsulation dot1Q 1500
no cdp enable
RTR01(config-subif)#service-policy output 8M
Tested with other sub-interface and no error:
interface GigabitEthernet0/2.1518
  bandwidth 1000
encapsulation dot1Q 1518
ip mtu 1500
ip flow ingress
ip flow egress
flow-sampler netflow-sampling
no cdp enable
RTR01(config-subif)#do sho policy-map int gi0/2.1518
  Service-policy output: 8M
    Class-map: class-default (match-any)
      2313 packets, 216535 bytes
      30 second offered rate 28000 bps, drop rate 0 bps
      Match: any
        30 second rate 28000 bps
      Queueing
      queue limit 2000 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 2313/216535
      shape (average) cir 8000000, bc 32000, be 32000
      target shape rate 8000000
      Service-policy : QOS
        queue stats for all priority classes:
I can imagine that your subif GigabitEthernet0/2.1500 had earlier  a different configuration, then you deleted it completely, and then re-created again with a new configuration. Some configuration can be still applied to this subif bit it will not be shown in a configuration.
ar
My setup here is:
LNS has individual QOS for authenticated subscribers.
Then one GE interface on that LNS is connected to the LAC.
Then I am applying a different aggregate shaper on this interface aside from the individual connected subs on LNS.
My guess is:
You cant really do QOS on the interfacing LAC on the same router together with subs shaper policy.
I hope someone can confirm it.
494
