7200
Dear Sir,
I have two IOs images in disk2 of 7206VXR . I want to boot the router with second image which is stored in disk2 .
I have already tried boot system flash disk2: IOS.bin command & bootldr but is not working
Help on same
Aman
Silver
Re: 7200
Hi Aman ,
1.First check whether is there any ios showing in run.
i.e boot system flash disk2:ios.bin
2.Then try to add the following commands to boot router using second image.
no boot system flash disk2:ios.bin ( first image)
boot system flash disk2:ios.bin (2'nd image)
reload the router using reload command and save the modified confiuration then type 'yes'.
Router will be booted using 2'nd image which is in disk2.
before that check the images using 'sh disk2' command and while giving the 'boot system flash ' type the correct image name.
satish
Re: 7200
DearSir,
I had tried the same procedure but does not seem to working.
I am attaching file which shows what exactly is happening.
Silver
Re: 7200
Hi Aman,
Use the followig commands.
no boot system flash disk2:c7200-is-mz.122-40.bin
boot system flash disk2:c7200-ik9s-mz.123-19.bin
save the system configuration before reloading the router.
If possible paste the 'sh version' and 'sh log'of the router.
Thx
satish
Re: 7200
I have a question. Would disk2 be in SLOT1 and not SLOT0 and would this physically be the BOTTOM slot on the router.?
This always confuses me.......
Re: 7200
Disk1 is slot0: and disk2 is slot1:
Re: 7200
So we can always assume that disk 1 will be in physical slot0 and disk 2 in physical slot1......right?
Re: 7200
yes, you are right.
Re: 7200
Thanks so much for the help everyone. Appreciated.
144
