Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
7206 E1 module
I want to purchase E1 module that are supported with plateform
Cisco 7206VXR (NPE-G2)
I have found a module PA-MCX-2TE1 and one is
PA-VXC-2TE1+ =2 port TE1 hi-capacity enhanced voice PA
Kindly tell me which module is best.
I am confuse about these module.
Waiting for reply,
thanks in Advance.
1 REPLY
Hall of Fame Super Gold
Re: 7206 E1 module
Hi, the VXC module is for voice, connect to pstn or a PBX, the MC and MCX modules are for data, connect a leased line, frame-relay, etc.
Hope this helps, please rate if it does!
159
