Community Member
7206 VXR boot up problem
Thre is a problem when booting up 7206 VXR router. Below is the log
System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMEN
T SOFTWARE
Copyright (c) 1994-2000 by cisco Systems, Inc.
C7200 platform with 524288 Kbytes of main memory
The fans works fine and I am able to enter the rommon mode...
Re: 7206 VXR boot up problem
hi
I feel we need more info on the same to help u out.
Is the booting hangs up after displaying this ? or is it proceeding further ?
Is it possible for you to post out a fresh log capturing the whole process from the power on to the hanging stage ?
also do you have any other IOS saved in the box ? if yes have you tried booting with the other ios code ??
regds
Community Member
Hi. Thank you for your reply.
The router stops after those 3 lines when booting up. There is only one IOS inside of it. The IO light on the front of the box is orange...
Community Member
· I/O controller: Provides the console connection, the auxiliary connection, the NVRAM, the Boot ROM, the Boot FLASH, and the built-in interface controller (either an Ethernet or Fast Ethernet interface). The I/O controller also provides access to the Flash memory cards in the PCMCIA card slot through PCI bus 0.
Source: http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a008009446a.shtml#identify
The most probable answer is stated above, as the router seem cannot load the software from the flash...
But im not sure what to do next..
162
