Community Member
7206 will not recognize PA-A3-8T1Ima card
switched slots, rebooted, reseated card..nothing I can not get it to recognize the card..any ideas?
appreciate the help
Hall of Fame Super Silver
Re: 7206 will not recognize PA-A3-8T1Ima card
Hello Jay,
you may need a different IOS image
you can check this using Feature Navigator
www.cisco.com/go/fn
or you can post a sh ver here
Hope to help
Giuseppe
Community Member
Here is the Sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.1(20), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 29-May-03 20:10 by kellythw
Image text-base: 0x60008950, data-base: 0x61562000
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 11.3(2)AA, EARLY DEPLOYMENT, RELEASE SOFTWARE (fc1)
udlext-r-001 uptime is 1 hour, 5 minutes
System image file is "slot0:c7200-is-mz.121-20.bin"
cisco 7206 (NPE200) processor (revision B) with 114688K/16384K bytes of memory.
Processor board ID 8770200
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
6 slot midplane, Version 1.3
appreciate the help!!!
Hello Jay,
I've used the sofware advisor tool in the hope of finding a suitable release for your device.
it provided the following feedback
Two or more selected items are incompatible. Selected item [PA-A3-8T1IMA=] is incompatible with: [NPE-200=-TS]. Please change one or more items.
So it looks like there is an hardware incompatibility
Hope to help
Giuseppe
Community Member
interesting..so the card is not compatable with the router hardware?
it was taken from one 7200 and put into another..will check to see what is was removed from..really appreciate the help..
Community Member
is it compatable with the following
NPE400
C7200-I/O-GE+E=
CLEI : CN3I3KOAAE
SPECIAL : 800-06117-08
Serial : 34676882
Hello Jay,
the incompatibility declared from the tool was with the NPE-200 not with the specified I/O controller.
for the tool with a C7206 chassis this I/O controller cannot be installed.
Be aware that both NPE-200 and C7206 chassis are end of sale since 2004 or before.
You may have taken the card from a C7206VXR chassis with NPE 400 or better processor.
sh c7200
Hope to help
Giuseppe
132
