7206VXR and PA-MC-T3 compatibility..
mlward
I have several hardware version 1.0.1 PA-MC-T3 cards running in non-VXR 7206 routers.  I would like to move them to a 7206VXR chassis, I understand that HW1.0.1 is not compatible with the VXR.  What HW version is required and can someone point me toward a document with that stated in it.  I would like to purchase the correct unit, but cannot locate the documentation with the minimum hardware version required.
Thanks Matt
Nagaraja Thanthry
The issue seems to be with NPE-G2 and the cards not 7206VXR and cards.
http://www.cisco.com/en/US/ts/fn/620/fn62535.html
As long as you are not using NPE-G2, you should be fine.
Hope this helps.
NT
The problem I have is that the cards will display that they are not compatible with the VXR and that they need to be removed.  I thought at one time, I had found a document that stated that hardware 1.0.1 cards would not work in the VXR, period.  I need this confirmed.
Matt
Matt,
Can you post a 'show diag' and any console messages which indicate that they are not compatible?
Not aware of any such document that talks about 1.0.1 hardware revision incompatibility
As far as I know, the PA should work with the 7206vxr with different NPEs; only the software version required may vary
