Webcast-Catalyst9k
7507 - IOS Upgrade?
I have a 7507 with the following boards installed:
- 1 GEIP controller
- 1 VIP4-50
- 2 Route/Switch Processor 16
IOS version: rsp-jsv-mz.124-3.bin
I intended to buy 2 additonals VIP-50 boards. Do i need to upgrade IOS in order to support the new boards?
Thanks in advanced,
1 REPLY
Silver
Re: 7507 - IOS Upgrade?
Only certain versions of code for the 7500 support VIPs, so you need to make sure you get one for that. Since you already have a VIP working, you dont need to worry. The IOS you are running will support more VIP4-50's.
99
