Webcast-Catalyst9k
7600 ES card shaping on VLAN
i am trying to apply Hierarchical policymap under a inter vlan it gives an error:
PE4(config)#int vlan 299
PE4(config-if)#service-policy output testce
Hierarchical policymap is not supported for this interface. Configuration failed!
here is the policy-map:
policy-map testce
class class-default
police 450000000
service-policy pe-ce-450m
Nested policy map:
policy-map pe-ce-450m
class pe-ce-450m-s
bandwidth percent 4
random-detect
random-detect precedence 0 300 1000 1
random-detect precedence 1 300 1000 1
class pe-ce-450m-p
bandwidth percent 30
random-detect
random-detect precedence 2 100 150 1
random-detect precedence 3 750 1000 1
random-detect precedence 6 750 1000 1
random-detect precedence 7 750 1000 1
class pe-ce-450m-nrt
police cir 292496000 bc 146248 be 4470 conform-action transmit exceed-action drop violate-action drop
is i use shaping than it says it is not supported.
policy-map testce
class class-default
shape average 450000000
service-policy pe-ce-450m -> same as above...
shape average command is not supported in output direction for this interface
how can we apply shaping on VLAN interface... subinterface configuration it works but not on VLAN interface.
Hall of Fame Super Bronze
Re: 7600 ES card shaping on VLAN
You are limited on features by applying the service-policy under the SVI
This document explains what features are available under the SVI and which aren't
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap7.html#wp1352261
HTH,
__
Edison.
Thanks.
Which card will offer H-QoS with SVI?
I have a situation where there are 2 trunk ports, connected two VPN Conc (active/backup), with SVI switchover is automatic, but need H-QoS to work, an card that car support it? IOS?
Any configuration made outside the 'specialty' module would be using the PFC QoS which is quite limited:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/qos.html
You need to come up with a design by using subinterfaces on the line card.
__
Edison.
ok.
following is what i think of, i don't like it but it may work:
two identical interfaces, 1 is shut down like primary is up and backup is down.
using EEM i track (using IP SLA) the primary as soon as it goes down i bring g2/16 up, and if EEM tracking disvocers 2/15 is backup it shouts down the g2/16 (which is backup).
cons: identical IP's on the two different interfaces, one is always shutdown.
let me know your thoughts. appereciate your help !~
interface GigabitEthernet2/15
description primary interface
no ip address
speed 1000
interface GigabitEthernet2/15.3455
encapsulation dot1Q 3455
ip vrf forwarding CPE-MGT
ip address 10.218.160.1 255.255.255.254
interface GigabitEthernet2/16
description backup interfaces
no ip address
shutdown
interface GigabitEthernet2/16.3455
For this kind of design, you should be using 'service instance'.
This URL should provide information on the subject
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html#wp1433480
HTH,
__
Edison.
261
