7600 SUP-720 3bxl
Hi All,
Trying to find a comparison between an Juniper M series router and the cisco 7600 router with sup-720 3bxl.In relation to that, would like to see a link which would provide the below details.
7600 Sup-720-3bxl(1 gb DRAM,512mb flash)
Maximum bgp instances ?
Maximum BGP peers ?
Maximum OSPF instances ?
Maximum OSPF routes ?
Maximum static routes ?
Meantime between failures(Bellcore Model) ?
If you could refer to any official cisco link,which could provide the above info would be great.
Any help is really appreciated.
Anantha Subramanian Natarajan
Hall of Fame Super Silver
Re: 7600 SUP-720 3bxl
Hi Giuseppe,
Thank you very much for the above details and its very useful.
I am not able to find these below specifics
Maximum BGP peers ?
Is it possible to find these values for sup-720-3bxl and as well as RSP720-3c-xl.
Once again,thank you
Anantha Subramanain Natarajan
Hello Anantha,
these are performance data in detail.
max bgp instance ?
1 you can have only one process but this comes from the protocol
max bgp peers ?
500 for sure, may be 1000 if not using aggressive timers.
max OSPF instances ?
32 but there is a feature for OSPF instances in VRF that goes beyond this
max OSPF routes ?
the limits are those of the protocol:
you shouldn't go over 5000-10000 routes in a single instance
max static routes ?
I don't know
I don't know
Hope to help
Giuseppe
Hi Giuseppe,
Thank you very much . Do you know any cisco official link with the above details mentioned.
309
