Community Member
7606 IOS that supports WS-X6582-2PA,PA-POS-10C3(SFP-IR-SM),and OSM-
Hi Team
Could someone advise which IOS images on 7606 can support WS-X6582-2PA,PA-POS-10C3(SFP-IR-SM),and OSM-2OC12-POS-SI+?
The current IOS is c6sup22-psv-mz.121-13.E6.bin.In order to support WS-X6582-2PA and PA-POS-1OC3(SFP-IR-SM),it?s suggested to upgrade to IOS12.2.18.We upgraded to s222-ipservices_wan-mz.122-18.SXF5.bin.It supports WS-X6582-2PA and PA-POS-1OC3(SFP-IR-SM).But when we installed OSM-2OC12-POS-SI+ it crashed.
Thank you very much for your help!
Tony
1 ACCEPTED SOLUTION
Silver
Re: 7606 IOS that supports WS-X6582-2PA,PA-POS-10C3(SFP-IR-SM),a
Hi Tony
You will need minimum IOS 12.2(33)SRA. This info is taken from "Supported Hardware for Cisco 7600 Series Routers with Release 12.2SR":
http://www.cisco.com/en/US/products/hw/routers/ps368/products_installation_guide_chapter09186a008069bb90.html
You can see that IOS version supports all of your modules but it requires Supervisor 720.
Silver
Hi Tony, please use configuration tool to enter all the module, info. and check which IOS is the min. ver. and you can also check the IOS release note or the module release note to check which IOS is required.
https://tools.cisco.com/qtc/config/html/configureHomeGuest.html
Please don't cross-post. Why did you not to find the ans. within Cisco internally ? It must be much faster and easier. Is it a quiz to Netpro user ?
Hope this helps.
Community Member
Hi Jack
Thank you very much for the info.It's very helpful.
Sorry for the crossposting.I am new to Cisco and am working on a dozen of cases at the same time.
thank you again for your help.I will soon get familiar with the cisco tools.
Best regards
Tony
Community Member
Hi Jack
Still need your help.I kept on searching but still haven't got what I want.Could you please advice which IOS supports all the following modules:
WS-X6582-2PA
OSM-2OC12-POS-SI+
Much appreciated.I'd love to know how you search for the IOS images.
Thank you again.
Tony
Silver
Hi Tony
Community Member
Hi Jose
Thank you so much for the info!It helps!
I finally know how to use the Cisco software advisor.
Again thank you very much for your help!
Tony
Silver
Tony. It is fine for me. It is great that you can access so many internal info. and share w/us in future. I believe it should be a hard work and need to learn so many knowledge in short period of time. Enjoy your new job.;)
649
