7609 to 3550 connectivity
Dear all,
  i m trying to connect 7609 Router to 3550 Sitch at one of thier fastethernet
on 7609 , interface been configured with ip 10.99.16.2 /29,
but couldnt configure  ip on 3550 side , what is to be done on switch end
also permitted the switch network which is 10.97.112.0 in ospf ,bgp routemap ACL on 7609
attached the switch config
1 REPLY
VIP Super Bronze
Re: 7609 to 3550 connectivity
Hi anandkumar,
Not clear what you are trying to do but
If you want to assign on IP to the port without using a vlan (a layer 3 routed port) then you need to enter no switchport under interface configuration command and than assign an IP to it.
Reza
151
