7613 atm card failure
I have a 7613 router with image "c7600rsp72043-adventerprisek9-mz.122-33.SRD2.bin" but my router cannot enable my SPA-4XOC3-ATM. I am getting this message "SPA-4XOC3-ATM card in subslot 1/0 is being disabled because of an incompatible FPD
image version. Note that the c7600-fpd-pkg.122-33.SRD2.pkg package will be required if you want to perform the upgrade operation". My problem here is how do I check the version before downloading the ios required? this is a new router and the ios that is on this router is the latest IOS.
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 7613 atm card failure
Hello Mpho,
my understanding is that the device is asking you to upgrade the firmware (FPD) of the SPA using the specified file:
So you should download this file that is not an ios image from cisco site and you should put it on the flash.
Hope to help
Giuseppe
1 REPLY
Hello Mpho,
Hope to help
Giuseppe
121
