8 Port Bri is not working
We had procured 8 port bri but when i installed on 2611 router it is disabling the slot.See below show diag output & sh ver.Please suggest if any issue with IOS or router.
Slot 1:
BRI (S/T) Port adapter, 8 ports
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.0 Board revision G0
Serial number 35018260 Part number 800-01237-03
FRU Part Number: NM-8B-S/T=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 21 01 00 02 16 56 14 50 04 D5 03 00 00 00 00
0x10: 80 00 00 00 06 06 09 17 FF FF FF FF FF FF FF FF
Router#sh ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(16a), RELEASE
SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 09-Nov-05 19:22 by evmiller
Image text-base: 0x80008098, data-base: 0x80CDC21C
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.3(16a), RELEASE SOFTWARE
(fc2)
Router uptime is 4 minutes
System image file is "flash:c2600-i-mz.123-16a.bin"
cisco 2611 (MPC860) processor (revision 0x203) with 35840K/5120K bytes
of memory.
Processor board ID JAD05030ANQ (3304218392)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
4 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
  • WAN Routing and Switching
Re: 8 Port Bri is not working
As far as I can find, this combination is indeed supported. RAM is also adequate.
Could you please log all output during boot and post it here?
This might give an idea of what is the problem here.
Leo
Please find the half boot output.rest will be in next message.
Proceed with reload? [confirm]y
00:08:19: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 40960 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x759774
Self decompressing the image : #### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
000092 0X000B3280 C2600 Dual Ethernet
000021 0X000C7B00 Octal port S/T interface Multi-BRI
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X004243F0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 5Mb.
Using 12 percent iomem. [5Mb/40Mb]
%DSX1-3-M32_AR_FAILURE: Munich 32 action request failure: Ctrl = 0x40840040, Channel = 32
-Process= "Init", ipl= 3, pid= 3
-Traceback= 8024EFB8 8024F430 8024F680 801BC49C 801BC534 801BD480 8050F70C 8050F800 8048D704 803A66D0 803A68D0 80494CC8 80498368
M32 initialization failed for slot 1, port 0
%MBRI-1-INITFAIL: Port Adapter in bay 1, shutting down PA
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
Self decompressing the image : ## [OK]
ID MEMORY_REQ TYPE
TOTAL: 0X004243F0
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Regard,
moorthy
Please find 2nd half boot output.
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(16), RELEASE SOFTWARE (fc4)
Compiled Tue 23-Aug-05 17:44 by ssearch
Image text-base: 0x80008098, data-base: 0x80CDBF04
cisco 2611 (MPC860) processor (revision 0x203) with 35840K/5120K bytes of memory.
Bridging software.
Press RETURN to get started!
*Mar 1 00:00:07.387: %DSX1-3-M32_AR_FAILURE: Munich 32 action request failure: Ctrl = 0x40840040, Channel = 32
*Mar 1 00:00:07.391: %MBRI-1-INITFAIL: Port Adapter in bay 1, shutting down PA
*Mar 1 00:00:10.152: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Mar 1 00:00:10.156: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up
00:00:11: %SYS-5-CONFIG_I: Configured from memory by console
00:00:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to up
00:00:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to down
00:00:13: %LINK-5-CHANGED: Interface Ethernet0/1, changed state to administratively down
00:00:14: %SYS-5-RESTART: System restarted --
00:00:14: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Router#sh diad g
Slot 0:
C2611 2E Mainboard Port adapter, 2 ports
Port adapter is analyzed
Hardware Revision : 2.3
PCB Serial Number : JAD05030ANQ (3304218392)
Part Number : 73-2840-13
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : C0
Deviation Number : 0-0
Product (FRU) Number : C2611 - 2E
EEPROM format version 4
0x00: 04 FF 40 00 92 41 02 03 C1 18 4A 41 44 30 35 30
0x10: 33 30 41 4E 51 20 28 33 33 30 34 32 31 38 33 39
0x20: 32 29 82 49 0B 18 0D 04 00 81 00 00 00 00 42 43
0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More--
Slot 1:
Router#
Moorthy
128
