815 vs. uBR905
How is the design of the Cisco 815 different from the Cisco uBR905 Cable Access Router?
1 REPLY
Blue
Re: 815 vs. uBR905
here are some specs. on the two devices you've mentioned:
815 - (network switch)
4 'switched' ethernet ports; 100Mbps (for user PC connections)
1 WAN port (for connection to DSL, CableModem)
1 aux port (can be used for dial-backup or Out-Of-Band management of the device)
1 serial console port (for local administration of the device)
1 integrated cable modem; DOCSIS 2.0 based
Supports the standard IP routing protocols, VLANs/interVLAN routing, QoS, stateful firewall, sofware VPN/IPSEC, 100Mbps link speed for PCs.
please see this link for more info on the 815:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd804b1b19.html
uBR905 - (network hub)
4 'shared' ethernet ports; 10Mbps only (for user PC connections)
1 USB port (925 model)
2 FXS ports (925 model; (used to connect analog telephony devices)
1 integrated cable modem; DOCSIS 1.1 based
Supports RIP/RIPv2 routing protocols, hardware 56 bit VPN/IPSEC (optional), 10Mbps only link speed for PCs, h323, mgcp, sgcp.
please see this link for more info on the uBR900 series:
http://www.cisco.com/en/US/products/hw/cable/ps2221/products_data_sheet09186a008008877d.html
if you have a choice, the 815 seems it has more built in features and is more flexible for small, changing environments.
106
