You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
831 Wan Question
Looking to find used Cisco Router for home lab / learning. I have and cable connection that is 30/3. I noticed that the 831 only have wan 10mb. Can this be upgraded? If not what would to recommend for low cost testing. I have several 2600's aswell as 2900xl's that I will be using for coursework.
Thanks for any advise
  • WAN Routing and Switching
Hall of Fame Super Gold
Re: 831 Wan Question
No.
As you mentioned you have some 2600 routers.  That's a good start.  Otherwise you need to fork out some cash for 850/870 routers.
The 2600's are 4 x serial units with one 56k card. What would you expect to pay for used 850? Thanks
1.  I have no idea what you plan to do but do you know that 850-series do not support multiple VLANs?
2.  This will depend on what WAN port is.  851 is a 10/100 WAN port and the 857 is an ADSL 2+ port.  The latter is very expensive ... above AU$300 .
179
