837 and DNS locally provided by DHCP
I have a 837 running and local PCs are connected getting their IP by local DHCP server on the 837. A DNS server address is provided to my by the ISP. Don´t know how I can make DHCP providing the ISPs DNS to the PCs ? Or do I have to run something like DNS forwarding ?
Chris
Re: 837 and DNS locally provided by DHCP
Please try the following:
Router(config-dhcp)# dns-server address [address2 ... address8]
The command specifies the IP address of a DNS server that is available to a DHCP client. One IP address is required; however, you can specify up to eight IP addresses in one command line.
thank you very much, but I would like to assign a DNS that is dynamically provided to me by the ISP rather than a static DNS.
Chris
Bronze
When doing a "sh dhcp server" you have a DNS0 and a DNS1, are those the 2 DNS servers you want to use in your local DHCP pool?
If that is the case just write "import all" in your DHCP pool config, like so:
ip dhcp pool A
import all
Please note that the DNS Domain name will allso be imported.
When I do a "sh dhcp server" I just get the following message:
DHCP server: ANY (255.255.255.255)
Leases: 0
Offers: 0 Requests: 0 Acks: 0 Naks: 0
Declines: 0 Releases: 0 Bad: 0
But the 837 is provided with the ISPs DNS and I can also use it from there ...
The ISP side provides the IPs by RADIUS server entries "Framed-IP-Address", the DNS by IPCP (on a Cisco 2610 with "ppp ipcp dns XX.XX.XX.XX"
Or do I have to use a real DHCP server on the 837 rather than just a DHCP pool in order to get the DNS for the clients ?
Chris
Bronze
OK, so your 837 is not configured with "ip address dhcp" rather it's "ip address negotiated".
Well I guess it should work anyway, did you try out the "import all"?
Do you think you could post the 837 config in the forum?
Hi tekha,
now it seems to be working with "import all" ! Thank you very much !
Best regards,
Chris
167
