837 and DNS/Routing Problem
Hello everybody,
I try to connect a 837 Router by an ADSL connection via a DSLAM to a 2610. (using PPPoA) On the network side I have a separate DNS running which can be reached from the 2610 (working as NAS) The ADSL connection seems to work properly. When I test the connection with the integrated tool in SDM I get the following error message:
"No configured DNS server(s) are routable through the selected interface. "
In details I can see that providing the IP from the NAS by IPCP seems to work. So it looks like a routing problem ?
Here is the config of the 837:
version 12.3
no service pad
hostname ADSL-Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret xxxxx
enable password xxxxx
no aaa new-model
ip subnet-zero
no ip routing
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.6 10.10.10.254
ip dhcp pool Local
import all
network 10.10.10.0 255.255.255.0
lease infinite
ip domain lookup source-interface ATM0.2
ip ips po max-events 100
no ftp-server write-enable
no crypto isakmp ccm
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
no ip route-cache
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
no ip route-cache
pvc 1/32
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
speed auto
full-duplex
interface FastEthernet2
shutdown
duplex auto
speed auto
interface FastEthernet3
shutdown
duplex auto
speed auto
interface FastEthernet4
shutdown
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip nat inside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxx
ppp chap password 0 xxxxxx
ppp ipcp dns request
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.2
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password xxxxx
login
transport input telnet
transport output telnet
scheduler max-task-time 5000
end
Here is the config of the 2610:
version 12.3
no service dhcp
hostname NAS-Router
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
no aaa new-model
ip subnet-zero
ip cef
ip domain lookup source-interface Ethernet0/0
ip domain name mydomain.com
ip name-server 192.168.14.2
username xxxxx password 0 xxxxx
controller E1 0/0
mode atm
ip address 192.168.14.1 255.255.255.0
half-duplex
no cdp enable
interface ATM0/0
no ip address
pvc 8/35
encapsulation aal5mux ppp Virtual-Template1
interface Virtual-Template1
ip unnumbered Ethernet0/0
peer default ip address pool kunden_isp1
ppp ipcp dns 192.168.100.2
ip local pool kunden_isp1 192.168.100.3 192.168.100.254
ip http server
ip classless
ip route 192.168.100.0 255.255.255.0 ATM0/0
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password xxxxx
login
end
I would really appreciate your help.
Chris
Hall of Fame Super Silver
Re: 837 and DNS/Routing Problem
Chris
I believe that SDM is expecting a configured DNS server and perhaps a configured domain name on the remote router similar to what you have configured on the head end router.
Rick
Hi Rick,
thanks for the answer.
But I would like to simulate a client who is not provided with any DNS information at all by his ISP. So maybe it would make sense to use DHCP on the NAS rather than IPCP ?
Chris
It seems to be a problem related to SDM, when I do everything straight in IOS it seems to work ... I get the propper IP address and DNS by IPCP ...
Still I can not ping anything on the remote side in no direction. What do I miss in the above settings ? I can not get the thing done.
I would highly appreciate your help.
Chris
104
