837 router - ip nat problem
hi,
I have this line in my router,
ip nat inside source static tcp 192.168.76.5 21 interface Dialer1 21
and it works just fine. now I want to do the same thing with ssh, when someone tries to connect to the outside interface using port 22 I want it to be forwareded to the server on port 22 but no success.
ip nat inside source static tcp 192.168.76.5 22 interface Dialer1 22
I also have this right now in my dialer 1 interface but still not working
ip access-group 101 in
access-list 101 permit ip any any
any ideas?
thank you.
Purple
Re: 837 router - ip nat problem
Can you attempt to establish an SSH session and then capture the output of 'sh ip nat translations' ?
Paresh
it works now, the same command works.
now I'm having troubles with ftp,
I have access-list 101 permit ip any any
with
my ftp connectio works but when I do ls(dir) to see the content it hangs.
I've tried this
ip nat inside source static udp 192.168.76.5 20 interface Dialer1 20
ip nat inside source static tcp 192.168.76.5 20 interface Dialer1 20
but no success, any ideas?
thanks.
Purple
You will certainly need the following 2 lines:
Can you make sure that the FTP client you are using is configured for Active mode ?
Hope that helps - pls rate the post if it does.
Paresh
107
