851 console trouble
hi all
I have 851 router that works in every way but it doesnt talk back thro console port. I will receive commands that i type in blindly ( getting good at it : ) )
I used a few diffent term programs and i now th serial port , cable and term progams all work becasue i checked them on cisco 2950 switch and a 878 router.
i managed to input all teh commands blind and manged to get at it useing the ip address. all that works fine.
i got it off ebay so have no idea whats happened to it before i got it
any ideas
thanks
andrew
851 console trouble
Check your console settings, start with 9600-N-8-1...
851 console trouble
ty for that  but thats all bin checked   as i said the router receives and process commands so settings much be right
Re: 851 console trouble
Have you tried using other baud rates? Try to crank it up and and find out which one works.
270
