Community Member
851W ISP DHCP problem.
Hello all,
I currently have a 851w at home and recently I wanted to use dynamic dns. So I configured everything for ddns and I couldn't get it to work. After some digging I discovered my ISP was setting my routers hostname as "newpc". Is there anyway to overwrite this to the hostname I want. The hostname of my router doesn't change to "newpc" but when it updates dynamic dns the router appends "newpc" instead of my hostname to the domain name. Here is the dhcp debug (I bolded the line where it sets my hostname) and I attached my config. Thanks for the help.
*Aug 12 00:02:09.903: RAC: Starting DHCP discover on FastEthernet4
*Aug 12 00:02:09.903: DHCP: Try 1 to acquire address for FastEthernet4
*Aug 12 00:02:09.907: DHCP: allocate request
*Aug 12 00:02:09.907: DHCP: new entry. add to queue, interface FastEthernet4
*Aug 12 00:02:09.907: DHCP: SDiscover attempt # 1 for entry:
*Aug 12 00:02:09.907: Temp IP addr: 0.0.0.0 for peer on Interface: FastEthernet4
*Aug 12 00:02:09.907: Temp sub net mask: 0.0.0.0
*Aug 12 00:02:09.907: DHCP Lease server: 0.0.0.0, state: 3 Selecting
*Aug 12 00:02:09.907: DHCP transaction id: 1E74
*Aug 12 00:02:09.907: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Aug 12 00:02:09.907: Next timer fires after: 00:00:04
*Aug 12 00:02:09.907: Retry count: 1 Client-ID: 001e.f790.16de
*Aug 12 00:02:09.907: Client-ID hex dump: 001EF79016DE
*Aug 12 00:02:09.907: Hostname: xxxxx.homedns.org
*Aug 12 00:02:09.907: DHCP: SDiscover: sending 290 byte length DHCP packet
*Aug 12 00:02:09.907: DHCP: SDiscover 290 bytes
*Aug 12 00:02:09.907: B'cast on FastEthernet4 interface from 0.0.0.0
*Aug 12 00:02:09.919: DHCP: Received a BOOTREP pkt
*Aug 12 00:02:09.923: DHCP: Scan: Message type: DHCP Offer
*Aug 12 00:02:09.923: DHCP: Scan: Server ID Option: 172.31.15.248 = AC1F0FF8
*Aug 12 00:02:09.923: DHCP: Scan: Lease Time: 604800
*Aug 12 00:02:09.923: DHCP: Scan: Renewal time: 302400
*Aug 12 00:02:09.923: DHCP: Scan: Rebind time: 529200
*Aug 12 00:02:09.923: DHCP: Scan: Subnet Address Option: 255.255.255.0
*Aug 12 00:02:09.923: DHCP: Scan: DNS Name Server Option: 64.233.217.2, 64.233.217.3
*Aug 12 00:02:09.923: DHCP: Scan: Domain Name: wowway.com
*Aug 12 00:02:09.923: DHCP: Scan: Router Option: 69.14.196.1
*Aug 12 00:02:09.923: DHCP: Scan: Time Offset: -28000
*Aug 12 00:02:09.923: DHCP: Scan: Time Server Option: 172.31.15.248
112
