857 ADSL 2+
PATRICK DUPONT
i just got a C857, it synch up without a problem 16megs*900 but for some reason it is not getting a IP from the ISP(Bell Canada)... can someone check the config n tell me what i am doing wrng?
sh run
Building configuration...
Current configuration : 4661 bytes
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip cef
ip domain name yourdomain.com
ip name-server 4.2.2.2
ip name-server 4.2.2.3
crypto pki trustpoint TP-self-signed-3071840133
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3071840133
revocation-check none
rsakeypair TP-self-signed-3071840133
crypto pki certificate chain TP-self-signed-3071840133
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303731 38343031 3333301E 170D3032 30333031 32323232
  33345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30373138
  34303133 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D3FD 09C9380A 9A82C26D 721B9001 BC7C95D4 9BDF5F7C 52113BAD BD7C5742
  83E5740E 10F15616 805F457A 3DC1C6DA 181E0925 A8E4C385 21FDE69C 8DAEDF42
  78C6FEB3 1578B53F 8EC3C62B BF91D935 698A98DE 1A726CA0 FE87D19E CFE5CACC
  F14FD705 CBA932B8 44AA09AC B5132E42 D4A3ABFE 07C1E504 0AD16F37 001EDE1B
  B5A70203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 145CA610 BE20DED8 85C93AFC B837B904 233FE1D0
  A9301D06 03551D0E 04160414 5CA610BE 20DED885 C93AFCB8 37B90423 3FE1D0A9
  300D0609 2A864886 F70D0101 04050003 8181001E 7E285063 5266A41D 696353FD
  DE06E9EF A6A23BC3 84F1E633 7FE77929 94F9C9EA 3BC686F8 C2542722 005F397B
  1F8AAF93 329D9602 2174BDF0 58798906 9815DAD7 8F02AE3E 8EF860B6 6C6D92FB
  F2567908 4459D5A3 A0C18363 F758142B FCFF32B5 A65C94C9 87F7A87F ED09A78B
  009F3FE6 1FBB1AE5 BEA39B12 361E6FFA C0A5BE
  quit
username xxxxxxxxx privilege 15 secret 5  xxxxxxxxxxxx
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/35
  oam-pvc manage
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxx
ppp pap sent-username xxxxx password 0 xxxxxxxx
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser>  privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
2 Accepted Solutions
Ian Jay
With 'ip address negotiated' you should be receiving an IP from your ISP.
'debug ppp negotiation' will tell you if the ISP is responding. You want to see PPP complete authentication and move to IPCP phase. If PPP does not complete negotiation, you will not receive an IP. Then its time to call the ISP and make sure you got the password right
/ijay
You are using the wrong password. Even if it seems right to you, it's wrong for the ISP.
Also, under dialer interface, configure "mtu 1492" that will speed-up negotiation.
16 Replies 16
Ian Jay
/ijay
Hi Ian,
ok i did my debug and have been racking my brain for a good part of the weekend why this is not working.. still no clue, i know what my password is it works with my 3wire modem... So right now i am lost as to why it is not working, provided a debug underneth maybe u can see something i missed..
Debug ppp nego
*Mar  3 03:20:50.835: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Mar  3 03:20:50.835: Vi1 PPP: Phase is DOWN, Setup
*Mar  3 03:20:50.835: Vi1 PPP: Using dialer call direction
*Mar  3 03:20:50.835: Vi1 PPP: Treating connection as a callout
*Mar  3 03:20:50.835: Vi1 PPP: Session handle[9800000E] Session id[0]
*Mar  3 03:20:50.835: Vi1 PPP: Phase is ESTABLISHING, Active Open
*Mar  3 03:20:50.835: Vi1 PPP: No remote authentication for call-out
*Mar  3 03:20:50.835: Vi1 LCP: O CONFREQ [Closed] id 1 len 10
*Mar  3 03:20:50.835: Vi1 LCP:    MagicNumber 0x1B5665FB (0x05061B5665FB)
*Mar  3 03:20:50.839: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar  3 03:20:51.035: Vi1 LCP: I CONFREQ [REQsent] id 150 len 18
*Mar  3 03:20:51.035: Vi1 LCP:    MRU 1492 (0x010405D4)
*Mar  3 03:20:51.035: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.035: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.035: Vi1 LCP: O CONFNAK [REQsent] id 150 len 8
*Mar  3 03:20:51.035: Vi1 LCP:    MRU 1500 (0x010405DC)
*Mar  3 03:20:51.035: Vi1 LCP: I CONFACK [REQsent] id 1 len 10
*Mar  3 03:20:51.035: Vi1 LCP:    MagicNumber 0x1B5665FB (0x05061B5665FB)
*Mar  3 03:20:51.055: Vi1 LCP: I CONFREQ [ACKrcvd] id 151 len 18
*Mar  3 03:20:51.055: Vi1 LCP:    MRU 1492 (0x010405D4)
*Mar  3 03:20:51.055: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.055: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.055: Vi1 LCP: O CONFNAK [ACKrcvd] id 151 len 8
*Mar  3 03:20:51.055: Vi1 LCP:    MRU 1500 (0x010405DC)
*Mar  3 03:20:51.087: Vi1 LCP: I CONFREQ [ACKrcvd] id 152 len 18
*Mar  3 03:20:51.087: Vi1 LCP:    MRU 1492 (0x010405D4)
*Mar  3 03:20:51.087: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.087: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.087: Vi1 LCP: O CONFNAK [ACKrcvd] id 152 len 8
*Mar  3 03:20:51.087: Vi1 LCP:    MRU 1500 (0x010405DC)
*Mar  3 03:20:51.107: Vi1 LCP: I CONFREQ [ACKrcvd] id 153 len 18
*Mar  3 03:20:51.107: Vi1 LCP:    MRU 1492 (0x010405D4)
*Mar  3 03:20:51.107: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.107: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.107: Vi1 LCP: O CONFNAK [ACKrcvd] id 153 len 8
*Mar  3 03:20:51.107: Vi1 LCP:    MRU 1500 (0x010405DC)
*Mar  3 03:20:51.123: Vi1 LCP: I CONFREQ [ACKrcvd] id 154 len 18
*Mar  3 03:20:51.127: Vi1 LCP:    MRU 1492 (0x010405D4)
*Mar  3 03:20:51.127: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.127: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.127: Vi1 LCP: O CONFNAK [ACKrcvd] id 154 len 8
*Mar  3 03:20:51.127: Vi1 LCP:    MRU 1500 (0x010405DC)
*Mar  3 03:20:51.143: Vi1 LCP: I CONFREQ [ACKrcvd] id 155 len 18
*Mar  3 03:20:51.143: Vi1 LCP:    MRU 1492 (0x010405D4)
*Mar  3 03:20:51.143: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.143: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.143: Vi1 LCP: O CONFREJ [ACKrcvd] id 155 len 8
*Mar  3 03:20:51.163: Vi1 LCP: I CONFREQ [ACKrcvd] id 156 len 14
*Mar  3 03:20:51.163: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Mar  3 03:20:51.163: Vi1 LCP:    MagicNumber 0x69FC4B94 (0x050669FC4B94)
*Mar  3 03:20:51.163: Vi1 LCP: O CONFACK [ACKrcvd] id 156 len 14
*Mar  3 03:20:51.163: Vi1 LCP: State is Open
*Mar  3 03:20:51.163: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar  3 03:20:51.163: Vi1 PAP: Using hostname from interface PAP
*Mar  3 03:20:51.163: Vi1 PAP: Using password from interface PAP
*Mar  3 03:20:51.167: Vi1 PAP: O AUTH-REQ id 1 len 22 from "b1xxxxx"
*Mar  3 03:20:51.335: Vi1 PAP: I AUTH-NAK id 1 len 18 msg is "Access Denied"<-------CHECK HERE
*Mar  3 03:20:51.335: Vi1 LCP: I TERMREQ [Open] id 157 len 4
*Mar  3 03:20:51.335: Vi1 LCP: O TERMACK [Open] id 157 len 4
*Mar  3 03:20:51.335: Vi1 PPP: Sending Acct Event[Down] id[6]
*Mar  3 03:20:51.335: Vi1 PPP: Phase is TERMINATING
Well both of u were right!!!! Damnit all this and changing my passwrd worked thank you very much to both of u...
PATRICK DUPONT
While i have u guys here, i am not sure if u can help me with the Cisco Wireless part i have figured out how to get something connected using WPA2, but i can not browse anywhere, i am ffar from being a Wireless config specialist and not sure if u guy are either but taking a chance u are lol..
857W#sh dot11 statistics client-traffic
Clients:
xxxxx.xxxx.xxxx pak in 1726 bytes in 109833 pak out 5 bytes out 713
      dup 0 decrpyt err 0 mic mismatch 0 mic miss 0
      tx retries 0 data retries 0 rts retries 0
      signal strength 51 signal quality N/A
Current configuration : 6357 bytes
version 12.4
no service pad
hostname 857W
boot-start-marker
boot-end-marker
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
resource policy
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
   import all
   network 10.10.10.0 255.255.255.224
   lease 0 2
ip cef
ip domain lookup source-interface Dialer0
ip ddns update method sdm_ddns1
HTTP
  add http:// /nic/update?system=dyndns&hostname=&myip=
  remove http:// /nic/update?system=dyndns&hostname=&myip=
  3082024B 308201B4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  69666963 6174652D 33303731 38343031 3333301E 170D3032 30333033 30333138
  35395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  B5A70203 010001A3 73307130 0F060355 1D130101 FF040530 030101FF 301E0603
  551D1104 17301582 13383537 572E796F 7572646F 6D61696E 2E636F6D 301F0603
  551D2304 18301680 145CA610 BE20DED8 85C93AFC B837B904 233FE1D0 A9301D06
  03551D0E 04160414 5CA610BE 20DED885 C93AFCB8 37B90423 3FE1D0A9 300D0609
  2A864886 F70D0101 04050003 8181002D 0EFFBA7A D8408B67 0816710C 0ABA171D
  3CC2013C AC96DFB0 C11D0C56 20A0B1F7 D4E60B69 568A6738 BE0E8FF6 D13BF852
  99BE5B82 CD08E977 07CC6B3A 27EA2136 DEF15AD3 B22DE93D E586F517 4318FF9F
  FC392A8B BE264CA1 330533DB AEBFF065 A35376CF 839258BD 9FCF8DCC 97C00C53
  2357B38A 75F6F4B2 9BC1CEEF FD35DC
  quit
username xxxxxxxx privilege 15 secret 5 xxxxxxxxxxxx
interface ATM0
no ip address
pvc 0/35
no ip address
ip nat inside
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid X-R0320C
    vlan 1
    authentication open
    authentication key-management wpa
    guest-mode
    infrastructure-ssid optional
    wpa-psk ascii 0 MynameisX15253
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
ip nat inside
dot1q tunneling ethertype 0x9100
interface Dialer0
bandwidth 16000
ip ddns update hostname xxxxxxxxxxx
ip ddns update sdm_ddns1
ip access-group 101 in
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp pap sent-username xxxxxx password 0 xxxxxx
ppp ipcp dns request
ppp ipcp route default
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip dns server
access-list 100 permit tcp any any
no cdp run
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
banner login ^C
username   privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use.
^C
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
end
Virtual LAN ID:  1 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interfaces:  Dot11Radio0.1
Virtual-Dot11Radio0.1
This is configured as native Vlan for the following interface(s) :
Dot11Radio0
Virtual-Dot11Radio0
   Protocols Configured:   Address:              Received:        Transmitted:
        Bridging        Bridge Group 1               1203                   3
   1206 packets, 72776 bytes input
   3 packets, 230 bytes output
   0 packets, 0 bytes input
   0 packets, 0 bytes output
Configure using console cable:
bridge irb
bridge 1 route ip
no interface Dot11Radio0.1
  no ip nat inside
  no ip virtual-reassembly
  bridge-group 1
interface Vlan1
  no ip address
  no ip nat inside
  bridge-group 1
interface BVI1
  ip nat inside
  ip tcp adjust-mss 1452
PATRICK DUPONT
When i do copy that into my config i get the Cnap error and can not see the wireless in my windows laptop???
857W(config)#int dot11Radio 0
857W(config-if)#no ip nat inside
%NAT: Error activating CNBAR on the interface Dot11Radio0
%NAT: Error activating CNBAR on the interface Virtual-Dot11Radio0
857W(config-if)#no ip virtual-reassembly
857W(config-if)#bridge-group 1
Configuration of vLAN subinterfaces and main
interface within the same bridge group is not permitted
Corrected config above.
Thanks All,
After fight for so long with this issue of cannot connect or connect can not browse, it ends up being a IOS BUG.. once upgraded all is good... now i am having another issue if someone can help me, my connection to browsing is extremely slow(with 2 wire it is fine), i have added my config my i am missing something just can ot seem t fins it, check MTU they are fine:
version 12.4
no service pad
hostname 857W
boot-start-marker
boot-end-marker
logging buffered 4096 warnings
aaa new-model
  69666963 6174652D 33303731 38343031 3333301E 170D3032 31303236 30353130
  31365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  8100B23A F4207F9E 32F7A4B5 058A5206 4C951FD0 47BA7944 53C194C9 070B7BC9
  E1735B1C 26FE8750 D71E5F3D F2423A0F CC9A9F96 E4ED3DB4 FC7FC96D 94C924B1
  2658B6EC 5C4BF000 1421E4F6 DC72CB58 EB86536E 450DB584 B33615F8 198D67DA
  92767A57 41AA8983 967A47CE 9833FB92 A7271CDE 25758E06 39868DCA ECB9A9B5
  C0510203 010001A3 73307130 0F060355 1D130101 FF040530 030101FF 301E0603
  551D2304 18301680 1403C621 949D2442 D0A43AC3 66B7599E BE211E18 EB301D06
  03551D0E 04160414 03C62194 9D2442D0 A43AC366 B7599EBE 211E18EB 300D0609
  2A864886 F70D0101 04050003 8181008C 29017B1E 8AEFE10F EE749D74 5DD47FE1
  6D4B3D57 48CEDA11 DB5D66B4 FA23ECEC C9E0D7A8 BF7DACE1 2166E6D4 2969A33E
  151A4F6D BF3B340E 07ACE078 0E283EE4 E9930E62 E3A9E4B5 9040A8FB 024E582B
  591903D6 F1A1F5A3 275D37DA A504C630 F1FC89DE B24A001F 49AC4B62 C19988C8
  16478FBB 0BBF0A8E F10F4B84 235EC6
        quit
dot11 syslog
dot11 ssid X-R0320W
   vlan 1
   authentication open
   guest-mode
no ip source-route
ip dhcp pool xxxxx
   import all
   lease infinite
ip dhcp pool vlan1
   import all
   dns-server 212.74.112.66 212.74.112.67
ip cef
ip domain name xxxxxxx.com
username meadmin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
pvc 0/35
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ssid X-R0320W
station-role root
no cdp enable
bridge-group 1
no cdp enable
bridge-group 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
bridge-group 1
interface Dialer0
bandwidth 16000
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxxxxxxxx
ppp chap password 0 xxxxxxxxx
ppp pap sent-username xxxxxxx password 0 xxxxxxxxx
interface BVI1
ip nat inside
ip forward-protocol nd
ip http server
ip nat inside source list 2 interface Dialer0 overload
logging trap debugging
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
bridge 1 route ip
banner exec ^C
% Password expiration warning.
^C
banner login ^CCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!Your IP is being logged^C
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
end
Configure:
interface ATM0
  default ip redirects
  default ip unreachables
  default ip proxy-arp
  no ip nat outside
  default ip route-cache
  spanning-tree portfast
  spanning-tree portfast!
  no ip nat inside
  default ip virtual-reassembly
  default ip route-cache flow
interface Vlan1
  no ip tcp adjust-mss 1452
interface BVI1
  ip tcp asjust-mss 1452
no ip route 0.0.0.0 0.0.0.0 Dialer0
nop has not helped what u gave me paolo, i even trided adjusting the MTU for my laptop amd still nothing has chnaged..
Repost of config:
Current configuration : 6294 bytes
version 12.4
no service pad
hostname 857W
boot-start-marker
boot-end-marker
aaa new-model
        quit
dot11 syslog
dot11 ssid X-R0230W
   vlan 1
   authentication open
   guest-mode
   wpa-psk ascii 0
no ip source-route
ip dhcp excluded-address 10.10.10.21 10.10.10.30
   import all
   dns-server 4.2.2.2 4.2.2.3
   lease infinite
ip dhcp pool vlan1
   import all
ip cef
no ip domain lookup
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
pvc 0/35
no ip address
encryption vlan 1 mode ciphers aes-ccm tkip
broadcast-key vlan 1 change 30
ssid X-R0230W
station-role root
no cdp enable
bridge-group 1
no cdp enable
bridge-group 1
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface Dialer0
bandwidth 16000
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname
ppp chap password 0
ppp pap sent-username  password 0
interface BVI1
ip address 10.10.10.1 255.255.255.224
ip nat inside
ip tcp adjust-mss 1460
ip http server
no cdp run
control-plane
bridge 1 route ip
banner exec ^C
Cisco Router and Security Device Manager (SDM) is installed on this device and
it provides the default username "cisco" for  one-time use. If you have already
used the username "cisco" to login to the router and your IOS image supports the
"one-time" user option, then this username has already expired. You will not be
able to login to the router with this username after you exit this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
use.
^C
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
end
Should be
int bvi1
Also check your ADSL speed: "show dsl interface".
