857w signal strenght weak
jonl711
client has 857w cannot get dhcp info to laptop (WXPPSP2). Have updated IOS on router. how can I check if router is ok?
paolo bevilacqua
Hi, the 857w has a good radio interface, certainly better than older 350 series (that was quite good) for example, I got weak clients at -92 db to connect and work!
You may want to inspect yourself with a trusted laptop the signal quality. Perhaps, do a netstumbler sweep and choose a channel in the most free space.
