871 router will not pass Telnet
Using VPN on DSL, with GRE tunnels, I find on 1/2 of the routers I cannot telnet through the router - even with the same config. It stops cold, while others pass telnet fine. What's the answer folks?? Jeff
1 REPLY
Re: 871 router will not pass Telnet
hi
Can you revert on the below points ..
1) To and from which ip you are trying to telnet ?
2) Are you trying to telnet from the local lan or from outside ?
3) Also the network topology you have in place at present ..
regds
275
