Community Member
871 - second alternative WAN connection
Hey
I want to make backup internet connection on 871 Cisco router.
I made belowe steps
  • One of the Vlan 1 port was changed into Vlan 2.
  • Vlan 2 now have static IP which is address for      second ISP.
  • Added route with priority 2.
Everything works fine, routing switching dynamically from one ISP to another.
Unfortunately I can’t resolve the problem of NAT.
In configuration is:
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.9.0 0.0.0.255
How to change that NAT will switch automatically and translate addresses depends from routing.
Re: 871 - second alternative WAN connection
Use a route-map.
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
route-map ISP1
  match ip address 101
  set ip next-hop x.x.x.x
route-map ISP2
  match ip address 102
  set ip next-hop y.y.y.y
ip nat inside source route-map ISP1 interface Fas0/0 overload route-map ISP1
ip nat inside source route-map ISP2 interface Fas0/1 overload route-map ISP2
The above example assumes the following:
192.168.1.0/24 = is the internal network
x.x.x.x = is the IP of the Fas0/0 (assuming that's the primary internet connection)
y.y.y.y = is the IP of the Fas0/1 (assuming that's the secondary internet connection)
Additionally you can use the IP SLA feature to track the routes.
Federico.
Community Member
Thanks for information.
Unfortunately something is wrong because ISP1 is working but the ISP2 not.
Where I made a mistake, maybe vlan is the problem??
This is conf.:
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description WAN2
switchport access vlan 2
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 10.14.62.83 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.9.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
ip address 192.168.11.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.14.62.81
ip route 0.0.0.0 0.0.0.0 192.168.11.1 2
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map ISP1 interface FastEthernet4 overload
ip nat inside source route-map ISP2 interface Vlan2 overload
logging trap debugging
access-list 101 permit ip 192.168.9.0 0.0.0.255 any
access-list 102 permit ip 192.168.9.0 0.0.0.255 any
no cdp run
route-map ISP2 permit 10
set ip next-hop 192.168.11.1
route-map ISP1 permit 10
set ip next-hop 10.14.62.81
Community Member
Below the configuration with solved problem.
Thanks for sugestion:
no cdp run
route-map ISP2 permit 11
match interface Vlan2
match interface FastEthernet4
continue 11
291
