871W with 2 WAN IPs
I currently have an 871W set up with the entire private, inside class C translated to an IP on the outside interface (F4). We currently have one web server on the inside which has 80 and 443 forwarded to it from the router, but will be assigning another IP to the web server's interface so it can host another site with SSL. I want to make sure this is going to work like I expect, my plan is to:
- Change the inside NAT pool for the current outside IP so that it doesn't encompass the entire class C network
- 1:1 NAT between the new outside IP and the new inside IP in the remaining range
Should this work?
1 REPLY
Purple
Re: 871W with 2 WAN IPs
Yep, that should work just fine.
Paresh.
119
