877 and DMVPN
Hi guys,
I appear to having a lot of issues qwith 877's. This paticular one is really annoying. If anyone could help i would appreciate it.
I setup one 877 on a hub site with the SDM standard DMVPN setup. This works fine.
i went to the remote site and configured the 877 there with SDM for DMVPN also. I have done this coutless times before without issue.
However it appears that when i ping from the router to thwe hub site i am getting errors. see below. It also appears that the GRE keepalives are causing the same errors to occur. The nature of the error does not sit comfortably with me. the tunnel drops out occasionally and i think performance is not as good as it should be.
D.Gold.Spoke#ping 172.16.3.201
Sending 5, 100-byte ICMP Echos to 172.16.3.201, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 136/180/344 ms
D.Gold.Spoke#
000099: Nov 2 12:14:16.236 UTC: %SYS-2-LINKED: Bad enqueue of 8337D134 in queue 82CA25C8
-Process= "<interrupt level>", ipl= 6, pid= 64
-Traceback= 0x807CB9D8 0x80023954 0x811A6310 0x8031B20C 0x80AF7840 0x80054AE4 0x8007A250 0x814AC710 0x814ACB5C 0x8134022C 0x817DA0DC 0x817D004C 0x817D2054 0x817D2180 0x817D2230 0x8034ACC4
000100: Nov 2 12:14:16.376 UTC: %SYS-2-LINKED: Bad enqueue of 8337D4C8 in queue 82CA25C8
000101: Nov 2 12:14:16.520 UTC: %SYS-2-LINKED: Bad enqueue of 8337D85C in queue 82CA25C8
000102: Nov 2 12:14:16.656 UTC: %SYS-2-LINKED: Bad enqueue of 8337DBF0 in queue 82CA25C8
000103: Nov 2 12:14:17.000 UTC: %SYS-2-LINKED: Bad enqueue of 8337DF84 in queue 82CA25C8
D.Gold.Spoke#
Can anyone explain what this is.
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Re: 877 and DMVPN
Stephen,
Are both the 877s, running same IOS ? Can you paste sh ver from both ?
Re: 877 and DMVPN
Hey,
Well both routers are now running IOS c870-advipservicesk9-mz.124-4.T
I can't get a sh ver the sites are not close to me.
I will try later
Stephen
Re: 877 and DMVPN
Are you still getting the errors, with IOS on both ends being same, and 12.4.4T is as high as you can go.
Re: 877 and DMVPN
Thanks for getting back to me. I Upgraded both 877s to the latest 12.4 IOS. The errors have now stopped, but another problem has developed. I can't get traffic throught the tunnels. I can ping all host from each side for the tunnel but i can't get any application traffic through. RDP, Groupwise, nothing appears to work correctly.
I have heard a rumour that the 8xx series are being held back from distibution. I wonder if my issues and the same many others appear to be having are the cause.
All the same any thought s on the above are appreciated.
Stephen
178
