Community Member
877 ATM point-to-point can't ping myself
Hi, I'm installing an 877 on an ADSL line. The config is as follows:
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 100.0.2.2 255.255.255.252
ip virtual-reassembly
no snmp trap link-status
atm route-bridged ip
pvc 0/40
protocol ip 100.0.2.1 broadcast
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.1.253 255.255.255.0
ip route 0.0.0.0 0.0.0.0 100.0.2.1
The DSL line is up, protocol up, interfaces are all green.
ping atm interface atm0.1 0 40
Sending 5, 53-byte end-to-end OAM echoes, timeout is 2 seconds:
BUT, I cannot ping myself!!!
ping 100.0.2.2
Sending 5, 100-byte ICMP Echos to 100.0.2.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Tried several configs, consulted with the DSL line provider, doesn't work. Can't ping myself and can't ping the gateway..
Any ideas?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 877 ATM point-to-point can't ping myself
Hi, try that:
int atm0.1
no ip address
no atm route-bridged ip
bridge-group 1
pvc 0/40
no protocol ip 100.0.2.1 broadcast
int bvi1
ip nat outside
bridge irb
bridge 1 route ip
Hi, try that:
int atm0.1
no ip address
bridge-group 1
pvc 0/40
int bvi1
ip nat outside
bridge irb
bridge 1 route ip
Community Member
Thanks, that helped to see my own IP!
Nevertheless, now I cannot ping the gateway (100.0.2.1) - the other end of the point to point link. The physical connection exists, the line is OK, the ISP checked their side, the gateway is OK. They can't ping me also.
Is there some kind of feature that needs to be turned on on the bridge interface? Besides the "bridge 1 route ip"?
Not really. Please send again the config, and output of "show atm pvc 0/40", "show bride 1 detail".
Community Member
Config:
version 12.4
bridge irb
interface ATM0
no ip address
pvc 0/40
bridge-group 1
interface Vlan1
interface BVI1
ip route 172.16.0.0 255.255.0.0 100.0.0.2
ip route 172.16.0.0 255.255.0.0 192.168.1.254
no ip http server
no ip http secure-server
access-list 100 permit ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.255.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Output:
Router#show atm pvc 0/40
Description: N/A
ATM0.1: VCD: 1, VPI: 0, VCI: 40
UBR, PeakRate: 121 (286 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0xC20, VCmode: 0x0, Encapsize: 12
OAM frequency: 0 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM END CC Activate retry count: 3, OAM END CC Deactivate retry count: 3
OAM END CC retry frequency: 30 second(s),
OAM SEGMENT CC Activate retry count: 3, OAM SEGMENT CC Deactivate retry count: 3
OAM SEGMENT CC retry frequency: 30 second(s),
OAM Loopback status: OAM Disabled
OAM VC Status: Not Managed
ILMI VC status: Not Managed
InARP frequency: 15 minutes(s)
InPkts: 0, OutPkts: 607, InBytes: 0, OutBytes: 30608
InPRoc: 0, OutPRoc: 607
InFast: 0, OutFast: 0, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 5
F5 InEndloop: 5, F5 InSegloop: 0,
F5 InEndcc: 0, F5 InSegcc: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 5
F5 OutEndloop: 5, F5 OutSegloop: 0,
F5 OutEndcc: 0, F5 OutSegcc: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
command "show bridge 1 detail" is not accespted, only "show bridge 1".
you never receive any packet on PVC 0/40, check with ISP that it is correctly provisioned. Have them ping your address, if counter doesn't increase, something is wrong.
Community Member
The ISP had an error. Now everything works.
Thank you for your help!
Yes, routers don't lie.
Good luck and Season Greetings!
670
