877 - DSL config
dcooke
Hi Guys
Couldn't find any answer to this anywhere so hope someone can help.
We are trying to connect our 877 DSL router to Verizon DSL. Of course they are no help at all as once you tell them you are using a Cisco router you may as well admit to having the Ebola virus!
I know the PVC settings are 0/35 from the previous router. I'm not sure about the encapulsation type. The last router had it as "routed bridge". I therefore presume that it should be RFC 1483 (aal5snap)?
Nothing is going on though. Here is the ATM config:
Interface ATM0
no ip address
no ip-route cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address xxxxx
ip nat outside
ip virtual-reassembly
no ip route-cache
pvc 0/35
encapsulation aal5snap
I have tried a few encapsulation types but with no luck. I can't ping the DSL gateway, also I can't ping the local ATM0.1 interface! is this normal.
Anyway - any help appreciated.
Dan
Hi, you have:
no ip routing
please re-enable ip routing, ip cef, and ip route-cache on applicable interfaces.
15 Replies 15
dcooke
Maybe I answered my own question when I asked it!
If you set int ATM0.1 to:
atm route-bridged ip
It works fine
There are two techniques. One is the one you found. The other use a BVI interface and is more common in configuration examples.
Thanks for the reply. I am now having a problem with PAT! Would you be able to help with this - or should I start a new thread? The NAT/PAT below looks OK to me - but no joy. The router can get out to the internet it just isn't translating inside packets to get outside ie a PC with IP 192.168.2.8 with gateway 192.168.2.1. NB I have not set the wireless up yet.
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.9
ip dhcp excluded-address 192.168.2.51 192.168.2.254
ip dhcp pool sdm-pool1
network 192.168.2.0 255.255.255.0
dns-server xxxxxxxxx
default-router 192.168.2.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no ip route-cache
ip address xxxxxxxxx 255.255.255.0
ip nat outside
no ip route-cache
pvc 0/35
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
no ip route-cache
bridge-group 8
interface BVI8
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxxxxxxxxx
ip http server
no ip http secure-server
ip nat inside source list 1 interface ATM0.1 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
bridge 8 protocol ieee
bridge 8 route ip
Seems fine to me. I would set "ip route cache" back on the other hand that cannot be causing the problem.
Take a traceroute from the PC and check that too.
Cheers. I'll see what that comes up with. Can't try until tommorow unfortunately.
Tried a tracert. I can ping and trace from a PC to the outside ATM interface, but I cannot trace to anything else. The dsl gateway times out from a PC - even though the router can ping it no problem.
I am a bit stumped! Any ideas?
Please send "show ip nat translations" when pinging from PC.
Also, xxxx in ip route 0.0.0.0 0.0.0.0, is that the IP address of the default GW, same that you're pinging ?
DAN,
I would know that you are trying to connect to your ISP with "route mode" or "bridge mode"
If you're trying to use the bridge mode then I haven't seen the bridge group mapping on the ATM interface.Let's ask your ISP to make life a bit easy.
Thot
Thot,
he has "atm route-bridged ip" and can ping from router. Likely an issue with the PC.
Thanks - I think I just lost a whole post so hopefully this isn't a repeat.
Yes, it looks likely to be a problem behind the router. I can ping the gateway (yes that is the xxxx in the route). I can also ping outside the gateway. I can also ping the ATM interface from another router on a different external network.
I'll try the show ip nat translations when pinging. When I looked at it previously everything was still 0. I tried debug ip nat - but didn't get anything.
I'll try tommorow (I'm in the UK and the router is in the US)
Thanks for your help.
Dan
Yes it looks like it isn't translating anything.
The sh ip nat translations list is blank (no entries) and the sh ip nat statistics is all zeros.
I'll try and recreate the nat and see if it does anything.
I rebuilt the NAT on VLAN1. The entire config is below. Still no translations taking place from inside to outside.
Where can I go from here? May have to admit defeat and raise a TAC!
!version 12.4
no service pad
hostname xxxxxx
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $xxxx
enable password xxxxxx
no aaa new-model
no ip routing
no ip cef
dns-server 71.x.x.12
archive
log config
hidekeys
interface ATM0
no ip address
no ip route-cache
ip address xxxxxx 255.255.255.0
ip nat outside
no ip route-cache
pvc 0/35
no ip address
no ip route-cache
shutdown
station-role root
interface Vlan1
ip nat inside
no ip route-cache
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password xxxxxxx
login
scheduler max-task-time 5000
end
Hi, you have:
no ip routing
Thanks p.bevilacqua . That sorted it! Still am confused though!
1) I thought IOS had routing turned on by default?
2) If it was needed why didn't the SDM turn it on?
3) If there is a default gateway I didn't think ip routing was needed?
Anyway, thanks very much for your help. Much appreciated.
Dan
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
