877 ROMmon upgrade
Hi all,
Somebody can tell me if I can upgrade ROMMON version 870_RM_ALT.srec.123-8r.YI4
C85x/C87x ROMMON Upgrade; Adds ADSL2/2+ annex M (C877M) support
To router version list bellow? If yes, how I need proceed?
------------------ show version ------------------
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(6)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 16-May-06 17:41 by kellythw
ROM: System Bootstrap, Version 12.3(8r)YI1, RELEASE SOFTWARE
HomeNetwork uptime is 4 minutes
System image file is "flash:c870-advipservicesk9-mz.124-6.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 877W (MPC8272) processor (revision 0x100) with 118784K/12288K bytes of memory.
Processor board ID FHK093414A1
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 802.11 Radio
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
Thanks in advance,
Ivan
1 ACCEPTED SOLUTION
Bronze
Re: 877 ROMmon upgrade
Yes you can. With the version of IOS you're running you have to drop to the ROMMON prompt and use the 'tftpdnld -u' command. More recent versions of IOS support the 'upgrade rom-monitor file' command in the 870 series. Checkout these Cisco and external links which describe the process:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/rommon.html
http://www.dslreports.com/forum/remark,15889237
http://www.dslreports.com/forum/r19925034-C85xC87x-ROMMON-Upgrade-Adds-ADSL22-annex-M-C877M-supp
Bronze
Hi Killian, Thanks for your help!
Problem solved!
Bronze
Glad to hear it :)
2669
