877 Routed Interfaces or 1800 series
I've been searching for router that can replace the obsolate 1720 that we have. I've started another post asking question about 837 router, but now my questions are about 877 or the 1800 series. The links to the ather post, in case that can help:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.1ddbd0a2
So what i want to do. I want to connect to the Internet with the ADSL router, and have 2 separated LANs. Of these LAN is like DMZ, so i can forward some internet ports to some servers in the 'DMZ'. The router is going to be used of about 10 persons, possible 2 or 3 vpns, almost that...
So I wanted to know what router to take, i found the 877, but i'm not sure if it has 2 routed interface, it has 4 port full managed switch, does it mean, that i can configure like that:
interface FastEthernet1
ip address 100.200.10.1
ip nat inside
interface FastEthernet2
ip address 100.200.20.1
ip nat inside
So that the LAN1 is connected respectively to the port 1 of the switch, and LAN 2 to the port2.
The 877 can do also VLAN, so a similar configuration is possible, right?
So, i'm not sure if i can take the 877 and configure the 4 interfaces separately or with the VLANs or to take other router. Pleace give some advises or propositions.
Here is some port of the configuration of the actual router 1720:
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode ansi-dmt
no fair-queue
hold-queue 224 in
interface ATM0.1 point-to-point
pvc 2/32
encapsulation aal5mux ppp dialer
pppoe-client dial-pool-number 1
interface Ethernet0
ip nat inside
full-duplex
interface FastEthernet0
ip address 100.200.20.45 255.255.255.0
ip nat inside
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname LOGIN
ppp chap password PASS
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.3 8080 SOMEIP 8080 extendable
ip nat inside source static tcp 192.168.1.2 80 SOMEIP 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip pim bidir-enable
access-list 1 permit 100.200.20.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 100.200.20.0 0.0.0.255
no cdp run
Thanks a lot!
Momchil
myanakiev@dia-gr.com
1 REPLY
Re: 877 Routed Interfaces or 1800 series
Hello Momchil,
the FastEthernet interfaces on the 877 router are indeed Layer 2 only, what you need to do is place each FastEthernet interface in a VLAN, and then configure SVI?s for inter-Vlan routing.
In your case, the configuration would look like this:
switchport access vlan 2
switchport access vlan 3
interface Vlan2
ip nat inside
full-duplex
interface Vlan3
ip nat inside
speed auto
The remainder of the PPPoA config is the same as for the 1720, define the dialer interface as NAT outside.
HTH,
GNT
118
