877W ADSL - Exit Interface Failed Test
russellmckee
Hi All,
first time request - hope someone can help...
i have purchased a Cisco 877W some weeks ago. i am trying to set it up over a home user ADSL service in the UK. The service is currently working using a basic netgear router.
i am hoping to replace the netgear to setup and test this router, but once setup the basic's using SDM the router is not able to succeed in all communication tests.
ERROR: no configured route to any of the DNS servers through the selected interface.
WAN Troubleshooting Report
ActivityStatus
Checking interface status...Up
Checking for DNS settings...Successful
Checking interface IP address..Successful
Checking exit interface...Failed
the router is connecting and obtaining a public address through DHCP from the ISP - however i am unable to get internet access from a client (on dhcp) and this DNS /exit interface test fails - (see above).
running config is as follows:
rtr-home-1#sho run
Building configuration...
Current configuration : 2045 bytes
version 12.4
no service pad
hostname rtr-home-1
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
dot11 syslog
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.9
ip dhcp excluded-address 10.10.10.100 10.10.10.254
ip dhcp pool ccp-pool1
   import all
   network 10.10.10.0 255.255.255.0
   dns-server 10.10.10.1
   default-router 10.10.10.1
ip name-server 10.10.10.1
archive
log config
  hidekeys
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
no ip route-cache
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password 0 PASSWORD
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ATM0.1 (also tried "Dialer0")
ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
access-list 100 remark CCP_ACL Category=2
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password PASSWORD
login
scheduler max-task-time 5000
end
Leo Laohoo
Didn't your ISP provide you their DNS server IP address?
ISP provides ip address, dns etc over dhcp. We didn't have to
configure any dns entries for the netgear.
Also as part of the test it establishes ip address and dns addresses
which was ok. The problem is connecting to the dns address's which
might also be why I cant route to the Internet.
I have been suggested to put in "ip routing". But what else do you
recommend?
Russ
Sent from my iPhone
On 4 May 2010, at 23:35, leolaohoo
From Test ADSL
I advise you to use public DNS such as OpenDNS (208.67.222.222 and 208.67.220.220) or Google's (8.8.8.8 or 8.8.4.4)
http://www.test-ligne-adsl.com
russellmckee
SOLVED
i believe i have fixed this by the following:
enable ip router:
configure terminal> ip routing
usign SDM ensure that default gateway is "Dialler0"
thanks for your help and assisitance. also useful to know about those open
dns servers...
