877w Wont Sync
I have an issue with an Cisco 877w where is wont sync with the line card in a BT exchange. It goes into a repeating up / down cycle and has been doing this now for several days. I have tried multiple adsl firmware's but none have worked. does anyone have any ideas. I dont have the config avilable but the config was working for 3 weeks prior to this occuring.
00:13:09: ATM0: atmsar_bringup_interface: Interface and atm_db flags are UP
00:13:11: ATM: Repapulate, ATM0
00:13:11: ATM: PVC activated, ATM0 VCD 1 (0/38)
Jun 18 12:32:08: %LINK-3-UPDOWN: Interface ATM0, changed state to up
00:13:11: atmsar_atm_lineaction(ATM0): state=4
Jun 18 12:32:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
00:13:14: DSL(ATM0): Defect: LCDi: retraining
00:13:16: ATM0: atmsar_1a_setup_vc, vcinfo = 0x85A2FE48
00:13:16: ATM0 atmsar_vc_setup: vcd 1
00:13:16: Fill up paramaters for PVC 0/38[1] - Request for CoS 0 PCR 0 SCR 0 MCR 0 Available 832
00:13:16: Scheduler parameters for 0/38. Type UBR. PCR 832
00:13:16: Total scheduled bandwidth after configuringPVC 0/38 will be 0
00:13:16: atmsar_setup_cos(ATM0): vc:1 wred_name:- max_q:0
00:13:16: ATM0: VC setup successful (vcd = 1)
00:13:16: ATM: PVC activated, ATM0 VCD 1 (0/38)
00:13:16: atmsar_atm_lineaction(ATM0): state=0
00:13:16: atmsar_1a_teardown_vc(ATM0): vc:1 vpi:0 vci:38
00:13:16: ATM(): IP multicast cache invalidated for ATM0
00:13:16: ATM: PVC removed, ATM0 VCD 1 (0/38)
00:13:16: DSL: SM: [DMTDSL_SHOWTIME -> DMTDSL_RE_OPEN]
00:13:16: DSL(ATM0): Send ADSL_CLOSE command.
00:13:16: DSL(ATM0): Sent command 0x4
00:13:17: DSL(ATM0): Received response: 0x25
00:13:17: DSL(ATM0): Connection closed
00:13:17: DSL: SM: [DMTDSL_RE_OPEN -> DMTDSL_DO_OPEN]
00:13:17: DSL(ATM0): Send ADSL_OPEN command.
00:13:17: DSL(ATM0): Using subfunction 0x0
00:13:17: LOCAL:Max noise margin for power cutoff 31
00:13:17: DSL(ATM0): Sent command 0x6
00:13:18: DSL(ATM0): Received response: 0x22
00:13:18: DSL(ATM0): Open failed: Error in early non-CRC message or in first CRC-covered message -- retrying
00:13:18: DSL(ATM0): sleep 5 seconds
Jun 18 12:32:15: %LINK-3-UPDOWN: Interface ATM0, changed state to down
00:13:18: atmsar_atm_lineaction(ATM0): state=0
Jun 18 12:32:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
00:13:19: ATM0: atmsar_vc_dlcx
00:13:23: DSL(ATM0): Send ADSL_OPEN command.
00:13:23: DSL(ATM0): Using subfunction 0x0
00:13:23: LOCAL:Max noise margin for power cutoff 31
00:13:23: DSL(ATM0): Sent command 0x6
00:13:25: DSL(ATM0): 1: Modem state = 0x9
00:13:28: DSL(ATM0): 2: Modem state = 0x10
00:13:30: ATM0 atmsar_1a_shutdown: state=6
00:13:30: ATM0: atmsar_shutdown, newstate = 6
00:13:30: DSL: SET: [DMTDSL_DO_OPEN -> DMTDSL_STOP]
00:13:30: Resetting ATM0
00:13:30: DSL: SM: [DMTDSL_DO_OPEN -> DMTDSL_STOP]
Jun 18 12:32:29: %LINK-5-CHANGED: Interface ATM0, changed state to administratively down
00:13:32: atmsar_atm_lineaction(ATM0): state=6
00:13:35: DSL(ATM0): Sent command 0x4
00:13:35: DSL(ATM0): Received response: 0x24
00:13:35: DSL(ATM0): Unexpected response 0x24
00:13:35: DSL(ATM0): Received response: 0x25
00:13:35: DSL(ATM0): Connection closed
Re: 877w Wont Sync
Also the line is good and has been for several years. It was typically syncing at around 7mbit prior to this issue.
877w#show dsl interface atm 0
ATM0
Alcatel 20190 chipset information
Line not activated: displaying cached data from last activation
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_STOP)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'STMI' 'IFTN'
Vendor Specific: 0x0000 0x71B9
Vendor Country: 0x0F 0xB5
Chip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Capacity Used: 99% 98%
Noise Margin: 14.5 dB 12.0 dB
Output Power: 20.0 dBm 11.0 dBm
Attenuation: 34.5 dB 16.0 dB
FEC ES Errors: 0 0
ES Errors: 42 26
SES Errors: 0 0
LOSES Errors: 0 0
UES Errors: 0 0
Defect Status: LCDi LOS LOF LCDi
Last Fail Code: None
Watchdog Counter: 0x13
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 28807 (0 spurious)
PHY Access Err: 0
Activations: 20
LED Status: OFF
LED On Time: 100
LED Off Time: 100
Init FW: init_3.0.33_nobist.bin
Operation FW: AMR-3.0.033.bin
FW Source: external
FW Version: 3.0.33
Interleave Fast Interleave Fast
Speed (kbps): 6208 0 832 0
Cells: 0 0 13297 0
Reed-Solomon EC: 0 0 194 196
CRC Errors: 397 0 195 209
Header Errors: 0 0 198 196
Total BER: 0E-0 0E-0
Leakage Average BER: 12288E-117 0E-0
Bitswap: enabled enabled
Re: 877w Wont Sync
Here is your error:
checked some forums, cant find a straight answer,
try changing the dsl auto settings on the atm0 if.
Please remember to rate useful posts, by clicking on the stars below.
Re: 877w Wont Sync
I have tried unless i am missing something silly.
Currently the mode is
dsl operating-mode itu-dmt
instead of
dsl operating-mode auto
Anyone other mode except for itu-dmt will not sync at all or produce an obvious error like other end is not configured to same operating mode.
463
