887 VPN with adsl and isdn as backup
Hi to all,
I have three router 887 I have to configure it in VPN using ADSL, but I want use the isdn interface as backup when ADSL fail to transport tunnel traffic. I have CCME and I have to ensure the voice traffic between offices also when adsl fails.
Anybody have a working example configuration, or suggestions?
Thank you very much
Augusto
Re: 887 VPN with adsl and isdn as backup
Do you already have the ISDN in place and Working?
Yes now there are 2511 with HDSL and ISDN backup, but not VPN.
So you are going to install the 887 routers, and keep the existing ISDN setup?
Do you run a dynamic routing protocol over the ISDN?
Are the ISDN lines always up, or are they activated with interesting traffic?
Thanks Andrew,
No, really I can change the existing ISDN setup, is not a must maintain it, now isdn backup is used only to ensure a web/mail, but then I have to ensure VoIP.
What do you it mean?
No not alway up, I need isdn backup start with all type of traffic only if ADSL goes down.
I made a config but I'm not sure it works:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes
group 2
crypto isakmp key pwdVPN address 222.222.222.222
crypto ipsec transform-set ESP-AES128-SHA ah-sha-hmac esp-aes esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to 222.222.222.222
set peer 222.222.222.222
set transform-set ESP-AES128-SHA
match address 103
interface BRI0
no ip address
encapsulation ppp
no ip route-cache
dialer pool-member 1
isdn switch-type basic-net3
isdn termination multidrop
isdn point-to-point-setup
interface ATM0
backup delay 10 30
backup interface Dialer0
no ip address
no ip route-cache
no atm ilmi-keepalive
service-policy output CCP-QoS-Policy-1
interface ATM0.1 point-to-point
description $FW_OUTSIDE$
ip address 88.88.88.88 255.255.255.252
ip access-group 100 in
ip nat outside
ip inspect CCP_LOW out
ip virtual-reassembly
no ip route-cache
pvc 8/35
  encapsulation aal5snap
interface FastEthernet0
switchport access vlan 100
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $FW_INSIDE$
ip address 192.168.20.254 255.255.255.0
ip access-group 102 in
ip nat inside
no ip route-cache
interface Vlan100
ip address 10.0.0.254 255.255.255.0
ip nat inside
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 180
dialer string 0000000000
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname user1
ppp chap password pwduser1
ppp pap sent-username user1 password pwduser1
no cdp enable
ip nat inside source route-map SDM_RMAP_1 interface ATM0.1 overload
ip nat inside source route-map SDM_RMAP_2 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip route 0.0.0.0 0.0.0.0 Dialer0 100
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip any any
access-list 103 remark CCP_ACL Category=4
access-list 103 permit ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 103 permit ip 10.0.20.0 0.0.0.255 10.0.10.0 0.0.0.255
access-list 104 remark CCP_ACL Category=2
access-list 104 deny   ip 10.0.20.0 0.0.0.255 10.0.10.0 0.0.0.255
access-list 104 deny   ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 104 permit ip 192.168.20.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address 104
route-map SDM_RMAP_2 permit 1
Thank a lot
Augusto
Looks OK - try it out and test it.
HTH>
926
