887va with public ip
mod0108537733
Dears;
I have 887va router that act as adsl modem and it working fine . I have one static public ip but iI dont know where to use it (under which interface)
I tried to use
r(config)#interface dialer1
r(config)#ip address x.x.x.x(the public ip)
instead of
r(config)#ip address negotiated
but doesn't work
10 Replies 10
Ali Norouzi
Do you establish PPPoE ?
yes with the command of
Hitesh Vinzoda
Level 4
Level 4
In some releases you cant assign /32 address under dialer interfaces.
so you have options
either use
or
int lo100
ip address x.x.x.x 255.255.255.255
int dia1
ip unnumbered lo100
Hitesh
pls rate useful posts
Dear Hitesh Vinzoda
the internet connection become down and  I cant telnet to the router from outside
I need this public ip to be used for site to site vpn with remote peer(any other solution will be appreciated)
thanks
Mahmoud
Hitesh Vinzoda
Level 4
Level 4
What option have you used?
Have you tried restarting router?
Sent from Cisco Technical Support Android App
My problem is I have two sites and want to make site to site vpn between them
(site A)  887va router and public ip
(site B)  ASA 5505 with public ip
I faced a problem related to 887va when I configured the ASA firewall for vpn I should use the 887va public IP
but I cant put this public ip under interface dialer in 887va (cisco documentaion said that). I dont care to use this public IP under dialer interface ,only I care about using this public ip  in vpn and access the router from outside by telnet .
any help please
Hitesh Vinzoda
Level 4
Level 4
Hi you would need to use IP address negotiated under dialer interface. Pls check with provider if they are pushing address via radius or LNS pool.
thanks Hitesh Vinzoda for your replay I appreciate that
I'm already using
the internernet is working fine but my question is in ASA what IP should I use for peer (887va router) if i make the the ip negotiated?
Please logon to the router and if your provider has given you a static IP then you can find that out using
> show ip int brief
Now if at all you dont know the IP address then from a PC behind the router go to www.whatismyipaddress.com
This will show you the external IP of the router. If all your other configuration on the router is OK.
Hitesh
I know that thanks
the dialer interface got public ip by negotiating but this ip is differnt from my assigned public ip from isp
is this ip will change after while?
can i use this negotiated ip in vpn ?
if i use anther public ip as a secondary under int vlan 1 any problem gonna be happen ?
