10-25-2006 11:03 PM - edited 03-03-2019 02:28 PM
Hi All,
There was a strange case rised on my customer environment. On my customer's Cisco 2811 w/ 12.4(10) or 2611XM w/ 12.3(10c), there are two dynamic ADSL line connecting to the WIC1ADSL card which are used with PPPoE settings(Dialer interface) to get internet connectivities. After these 2 lines or one of them dialed up to ISP, they get 2 public IP addresses on dialer interfaces, but I find that there is a connected route added to the routing table, I suspect that the host in the route entry is a host inside the ISP. This route entry is not in existance when the ATM interface goes down. And this case never happened on my other customer. So I would like to ask anyone who knows why a CONNECTED route entry automatically added to the routing table of the router? This case still happens even I reset the router to dummy setting which only serves the PPPoE.
The routing table is like the following:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
100.x.100.0/32 is subnetted, 1 subnets
C 100.x.100.29 is directly connected, Dialer1
99.0.0.0/32 is subnetted, 1 subnets
C 99.31.47.18 is directly connected, Dialer1
C 192.168.1.0/24 is directly connected, Loopback0
S* 0.0.0.0/0 is directly connected, Dialer1
Note: 100.100.100.29 is the suspected entry. This IP and route entry is constant after both or one of the 2 broadbands dialed up to ISP. 99.x.x.18 is the IP of dialer1 interface.
The following is the dummy settings on 2611XM:
hostname 2611
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
vpdn enable
interface Loopback0
ip nat inside
interface ATM0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 1/33
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username test password test
ip nat inside source list 100 interface Dialer1 overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
end
Thanks!
Jason
10-25-2006 11:58 PM
This is typically the IP of the virtual-template which the ISP has created on the LNS. Not sure why the route is inserted probably for an end-to-end Layer 3 connectivity over the PPP network.
10-26-2006 05:37 AM
Jason
The addition of a /32 route in the routing table is a result of the ppp negotiation that is part of the dialer interface configuration with address negotiated. Inserting the /32 is normal and I do not see that it causes any problem. Is there a reason that you are concerned about it?
I am wondering about this statement:
100.100.100.29 is the suspected entry. This IP and route entry is constant after both or one of the 2 broadbands dialed up to ISP. 99.31.47.18 is the IP of dialer1 interface.
I believe that 100.100.100.29 is the address of the device on the other end of the ppp connection. I do not understand how 99.31.47.18 is the address of the dialer interface. Perhahps you could post the output of show ip interface brief along with the output of show ip route so that we can understand the relationship better.
It might be very interesting and informative if we could see the output of debug ppp negotiation.
Rick
