10-19-2011 04:57 PM - edited 03-04-2019 01:59 PM
Just wondering if anyone has seen this and what their thoughts are WiSM blade is in port one of my 6509:
Firmware compiled 03-Jun-11 12:45 by integ Build [100] Oct 19 21:35:22.443: %SYS-CFC1-5-RESTART: System restarted -- Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXJ1, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2011 by Cisco Systems, Inc. Compiled Wed 22-Jun-11 18:02 by prod_rel_team Oct 19 21:35:22.451: CFC1: Currently running ROMMON from S (Gold) region *Oct 19 21:35:23.003: %OIR-SP-6-INSCARD: Card inserted in slot 8, interfaces are now online *Oct 19 21:35:25.040: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics... *Oct 19 21:35:35.499: %MLS_RATE-4-DISABLING: The global switching mode is now 'truncated'. Disabling the Layer2 Rate Limiters. *Oct 19 21:35:34.954: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics *Oct 19 21:35:38.145: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online *Oct 19 21:35:39.952: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics *Oct 19 21:35:40.476: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online *Oct 19 21:35:41.064: %EC-SP-5-CANNOT_BUNDLE2: Gi1/1 is not compatible with Po401 and will be suspended (trunk mode of Gi1/1 is dynamic, Po401 is trunk) *Oct 19 21:35:41.064: %EC-SP-5-CANNOT_BUNDLE2: Gi1/2 is not compatible with Po401 and will be suspended (trunk mode of Gi1/2 is dynamic, Po401 is trunk) *Oct 19 21:35:41.068: %EC-SP-5-CANNOT_BUNDLE2: Gi1/3 is not compatible with Po401 and will be suspended (trunk mode of Gi1/3 is dynamic, Po401 is trunk) *Oct 19 21:35:41.068: %EC-SP-5-CANNOT_BUNDLE2: Gi1/4 is not compatible with Po401 and will be suspended (trunk mode of Gi1/4 is dynamic, Po401 is trunk) *Oct 19 21:35:41.068: %EC-SP-5-CANNOT_BUNDLE2: Gi1/5 is not compatible with Po402 and will be suspended (trunk mode of Gi1/5 is dynamic, Po402 is trunk) *Oct 19 21:35:41.072: %EC-SP-5-CANNOT_BUNDLE2: Gi1/6 is not compatible with Po402 and will be suspended (trunk mode of Gi1/6 is dynamic, Po402 is trunk) *Oct 19 21:35:41.072: %EC-SP-5-CANNOT_BUNDLE2: Gi1/7 is not compatible with Po402 and will be suspended (trunk mode of Gi1/7 is dynamic, Po402 is trunk) *Oct 19 21:35:41.076: %EC-SP-5-CANNOT_BUNDLE2: Gi1/8 is not compatible with Po402 and will be suspended (trunk mode of Gi1/8 is dynamic, Po402 is trunk) *Oct 19 21:35:41.392: %EC-SP-5-CANNOT_BUNDLE2: Gi1/1 is not compatible with Po401 and will be suspended (trunk mode of Gi1/1 is dynamic, Po401 is trunk) *Oct 19 21:35:41.392: %EC-SP-5-CANNOT_BUNDLE2: Gi1/2 is not compatible with Po401 and will be suspended (trunk mode of Gi1/2 is dynamic, Po401 is trunk) *Oct 19 21:35:41.392: %EC-SP-5-CANNOT_BUNDLE2: Gi1/3 is not compatible with Po401 and will be suspended (trunk mode of Gi1/3 is dynamic, Po401 is trunk) *Oct 19 21:35:41.392: %EC-SP-5-CANNOT_BUNDLE2: Gi1/4 is not compatible with Po401 and will be suspended (trunk mode of Gi1/4 is dynamic, Po401 is trunk) *Oct 19 21:35:41.396: %EC-SP-5-CANNOT_BUNDLE2: Gi1/5 is not compatible with Po402 and will be suspended (trunk mode of Gi1/5 is dynamic, Po402 is trunk) *Oct 19 21:35:41.396: %EC-SP-5-CANNOT_BUNDLE2: Gi1/6 is not compatible with Po402 and will be suspended (trunk mode of Gi1/6 is dynamic, Po402 is trunk) *Oct 19 21:35:41.396: %EC-SP-5-CANNOT_BUNDLE2: Gi1/7 is not compatible with Po402 and will be suspended (trunk mode of Gi1/7 is dynamic, Po402 is trunk) *Oct 19 21:35:41.396: %EC-SP-5-CANNOT_BUNDLE2: Gi1/8 is not compatible with Po402 and will be suspended (trunk mode of Gi1/8 is dynamic, Po402 is trunk) *Oct 19 21:35:41.744: %EC-SP-5-CANNOT_BUNDLE2: Gi1/2 is not compatible with Po401 and will be suspended (trunk mode of Gi1/2 is dynamic, Po401 is trunk) *Oct 19 21:35:41.744: %EC-SP-5-CANNOT_BUNDLE2: Gi1/3 is not compatible with Po401 and will be suspended (trunk mode of Gi1/3 is dynamic, Po401 is trunk) *Oct 19 21:35:41.744: %EC-SP-5-CANNOT_BUNDLE2: Gi1/4 is not compatible with Po401 and will be suspended (trunk mode of Gi1/4 is dynamic, Po401 is trunk) *Oct 19 21:35:41.752: %EC-SP-5-CANNOT_BUNDLE2: Gi1/6 is not compatible with Po402 and will be suspended (trunk mode of Gi1/6 is dynamic, Po402 is trunk) *Oct 19 21:35:41.752: %EC-SP-5-CANNOT_BUNDLE2: Gi1/7 is not compatible with Po402 and will be suspended (trunk mode of Gi1/7 is dynamic, Po402 is trunk) *Oct 19 21:35:41.752: %EC-SP-5-CANNOT_BUNDLE2: Gi1/8 is not compatible with Po402 and will be suspended (trunk mode of Gi1/8 is dynamic, Po402 is trunk) *Oct 19 21:35:42.128: %EC-SP-5-CANNOT_BUNDLE2: Gi1/3 is not compatible with Po401 and will be suspended (trunk mode of Gi1/3 is dynamic, Po401 is trunk) *Oct 19 21:35:42.128: %EC-SP-5-CANNOT_BUNDLE2: Gi1/4 is not compatible with Po401 and will be suspended (trunk mode of Gi1/4 is dynamic, Po401 is trunk) *Oct 19 21:35:42.132: %EC-SP-5-CANNOT_BUNDLE2: Gi1/7 is not compatible with Po402 and will be suspended (trunk mode of Gi1/7 is dynamic, Po402 is trunk) *Oct 19 21:35:42.132: %EC-SP-5-CANNOT_BUNDLE2: Gi1/8 is not compatible with Po402 and will be suspended (trunk mode of Gi1/8 is dynamic, Po402 is trunk)
10-19-2011 09:52 PM
Hi Timothy,
Can you share ether-channel and member port config please.
Also, I assume for ether-channel is L2 right ???
I suspected, hard coding the port to trunk instead of auto negotiation should solve the problem.
However, still needs to see the config before suggesting something concrete.
HTH,
Smitesh
10-19-2011 10:08 PM
Interfaces Gig 1/1 to 8 is configured with "switchport trunk desirable" while the Portchannel interface 401 and 402 is configured as "switchport mode trunk".
Here's how you fix this one up:
1. no interface po 401;
2. no interface po 402;
3. interface range g 1/1 - 4
4. switchport mode trunk
5. channel-group 401 mode on
5. interface range g 1/5 - 8
6. switchport mode trunk
7. channel-group 402 mode on
10-25-2011 09:57 AM
Similar to Leo's reply, but I couldn't remove the Port-Channels when I had the issue. Probably code-dependent interaction with Auto-LAG. I solved this issue by removing and re-applying the VLANs: no wism module slot controller <1/2> allowed-vlan xx,yy,zz wism module slot controller <1/2> allowed-vlan xx,yy,zz
