Hi all.
I will shortly be getting an 857/877 ADSL router and have a few questions regarding the setup with my infrastructure.
I have 10 static IP's from my ISP. 1 is for the WAN on the ADSL router, 1 is used for the external I/F of my Checkpoint. I have a DMZ with a web server and mail server. The DMZ / internal machines are connected to a managed VLAN capable switch with no routing between them.
Example:
WAN IP: 82.33.104.102
External I/F on Checkpoint: 82.33.104.103
DMZ I/F on Checkpoint: 192.168.1.250
Internal I/F on Checkpoint: 10.0.10.250
I should be able to just hook up my 877 to the external facing I/F on my Checkpoint right and let it handle the traffic that way? Any special config or routing I need?
Any problems do you think with this kind of setup? (I intend to do all firewalling via the Checkpoint).
Any help would be very much appreciated.
Thanks.
