08-23-2008 02:42 PM - edited 03-03-2019 11:14 PM
Why does the corresponding serial interface of an E1 link show the default BW as 1984Kbit instead of the line data rate (=2048Kbit) or its actual data rate (64X30 = 1920Kbit) without framing and signaling ?
The confusion is that according to my understanding typical serial interface BW value is 1544Kbit irrespective of the link it is attached to.
Is interface BW value simply related to the number of time-slots allocated(in the context of E1)?
08-23-2008 10:40 PM
sure
each B channel is 64K
08-24-2008 02:39 AM
First of all you need to check with your ISP whether the E1 link is Structured or unstructured.
Unstructured E1 will use all 32 timeslots (TS0 - TS31)for data ( 32x64 = 2048K)
However in case of structured E1, it uses 31 timeslots (TS1 - TS31) (31x64 = 1984K)
08-24-2008 02:46 AM
what u meant in stractured and non-stractured
i guess u mean inband and out of band signaling
inband use 32 channel out of band use 31 and the d channel will be dedcated for signalling!!
AKA CAS CCS
08-24-2008 03:49 AM
Theis may be even called as Framed and unframed CKTS
framed ckts/unframed CKTS - we get full 2048K Bandwidh ( When Using VWIC-1MFT-G703 or VWIC2-2MFT-G703 WAN Card)
if we use VWIC-1MFT-T1/E1 or VWIC2-2MFT-T1/E1 WAN Card) one time slot is used for Signalling and we get 1984Kbps only.
Note:
When changing the WAN card make sure that the service provider does the changes to get the link up.
08-24-2008 04:12 AM
Hi Srini,
Yes, G703 is meant for that and can get full 2048K.
