06-26-2006 04:37 PM - edited 03-03-2019 01:08 PM
Hi folks,
what the difference between bgp graceful-restart and peer soft-reconfiguration? The first is only for dual route processors systems, or maybe the behavior is quite different?
Thanks for your support
Andrea
Solved! Go to Solution.
06-27-2006 06:12 AM
soft-reconfiguration will store all BGP updates from a neighbor in memory, i.e. you have an exact copy of the updates BEFORE your filters. Thus "clear ip bgp
Once your route processor dies, however, all BGP sessions die. Once the session is terminated also the "soft" copy in memory is removed and the forwarding table is cleared.
So bgp graceful-restart addresses this problem: one RP dies and a second one is present to take over. The line cards will keep the forwarding table though the BGP session is gone until BGP establishes full connecivity again. The result is: your users will have less disruption (if any).
Hope this helps! Please rate all posts.
Regards, Martin
06-27-2006 06:12 AM
Regards, Martin
