Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
about c1921 interface gigabitethernet set speed 10 and duplex full
Hi all:
when I config c1921 interface "speed 10 and duplex full" .
I pinged gateway will be lost a lot of packets.
and the CRC counts are very high.when I set speed 10 and duplex auto.then everything will be fine.
but the company standards are must be set speed 10 and duplex full.so how can I do this.
PS:rj45-auto-detected polarity is disabled.
there is my command
int gi0/1
ip add x.x.x.x x.x.x.x
speed 10
duplex full
rj45-auto-detected polarity disabled
no shutdown.
no
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
What are you connection to
What are you connecting to directly from g0/1? If you're specifying 'duplex full' but the other side is 'duplex auto', you're probably negotiating to half on the other end which is where your errors are coming from. You'll need to get into the device that g0/1 is connecting to and hardcode it to 10/full as well and you should be okay...
HTH,
John
HTH, John *** Please rate all useful posts ***
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Or, you might try leaving your 1921 at auto/auto.
Speed is almost always correctly discovered - at the best common.
Duplex is also usually correctly discovered unless the other side is hard code full or is an "old" interface.
HTH,
John
Super Bronze
Disclaimer
Posting
54
