About int tunnel
Hi netpro:
I have so trouble aboute int tunnel. I can't ping the local int tunnel successfully wether the destination add is local int address or remote int address .
the config is :
interface Tunnel0
ip address 10.10.10.1 255.255.255.252
tunnel source 192.168.1.1 (local loopback 0)
tunnel destination 192.168.2.1 (local loopback 1)
end
the cef is off
TestRouter#sh ver
IOS (tm) RSP Software (RSP-JSV-M), Version 12.1(9), RELEA
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 13-Jun-01 18:36 by kellythw
Image text-base: 0x60010958, data-base: 0x6145C000
ROM: System Bootstrap, Version 11.1(2) [nitin 2], RELEASE
TestRouter uptime is 4 weeks, 5 days, 19 hours, 47 minute
System returned to ROM by reload at 12:11:36 UTC Sun Jun
System image file is "slot0:rsp-jsv-mz.121-9.bin"
cisco RSP2 (R4700) processor with 131072K/2072K bytes of
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology
Bridging software.
TN3270 Emulation software.
Chassis Interface.
1 EIP controller (2 Ethernet).
2 SSIP controllers (16 Serial).
2 Ethernet/IEEE 802.3 interface(s)
16 Serial network interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash PCMCIA card at slot 0 (Sector size
8192K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 3.
TestRouter#ping
Protocol [ip]:
Target IP address: 192.168.2.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.1.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
TestRouter#
TestRouter#ping 10.10.10.1
Sending 5, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
please give me some advice , thank you.
Re: About int tunnel
are u able to ping 10.10.10.2?? are there any ACLs configured on these routers?
Raj
I can ping peer tunnel address ,and no acl,thank u .
Hi Zhou
Can you post the config of your router ?
Also can you include the output of show ip route taken out from your router ?
regds
Hi spremkumar :
this is output :
sh ip route
Gateway of last resort is not set
18.0.0.0/24 is subnetted, 1 subnets
C 18.18.18.0 is directly connected, Ethernet1/0
10.0.0.0/30 is subnetted, 1 subnets
C 10.10.10.0 is directly connected, Tunnel0
C 192.168.1.0/24 is directly connected, Loopback11
192.168.2.0/32 is subnetted, 1 subnets
C 192.168.2.1 is directly connected, Loopback2
TestRouter#
TestRouter#sh ip int tunnel 0
Tunnel0 is up, line protocol is up
Internet address is 10.10.10.1/30
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1490 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP Fast swi
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP Fast switching turbo vector
IP Normal CEF switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
and show run int tunnel0
Current configuration : 123 bytes
interface Tunnel0
end
TestRouter#
thank u.
Hi Zhou
As i already mentioned would suggest to post out the full config of both the routers since both your loopbacks loopback 1& 2 are showing as directly connected and you are using them as source and destination address of your tunnel.
Tunnel destination should be the remote end routers loopback address and you should have reachability to the same..
regds
199
