Silver
about NVI
Hi folks,
what is exactly a NAT Virtual Interface, and when I've to use it?
thanks for your support
Andrea
  • WAN Routing and Switching
Silver
Re: about NVI
Hello Andrea,
Take a look at the documentation for NVI.
Basically a NAT Virtual Interface feature allows all NAT traffic flows on the virtual interface, eliminating the need to specify inside and outside domains.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiad_c/ch20/ntbaddrs.htm#wp1084652
--Leon
* Please rate posts.
Silver
Re: about NVI
thanks Leon,
I've already seen that ... but could you send me an example, to explain when I've to use NVI, and when normal 'ip nat inside - ip nat outside'?
Thanks for your support
Andrea
265
