access SBS 2011 owa using ASA 5505
Hi there, i am new in the ASA world but i have managed to set up an ASA. Everything works fine but i am not able to access the OWA through the Cisco ASA. Find the config below. Can somebody assist me?
Thanks!
: Saved
ASA Version 8.3(1)
hostname asa2
enable password i9.yhWTfK7AnxZ5r encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.131.8 sbs
interface Vlan1
nameif inside
security-level 100
ip address 192.168.131.152 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.xx.5 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_192.168.131.128_25
subnet 192.168.131.128 255.255.255.128
object network exchange
host 192.168.131.8
object service https
service tcp source eq https destination eq https
object-group service owa tcp
port-object eq https
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit object https any interface outside
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in remark Allow SMTP traffic
access-list outside_access_in remark Allow SSL-OWA-RWA Traffic
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in remark Allow SharePoint traffic
access-list outside_access_in extended permit tcp any interface outside eq 987
access-list inside_access_out extended permit ip any any
access-list global_access extended permit ip any any inactive
access-list inside_access_in extended permit ip any any
access-list outside_access_out extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool mediostpool 192.168.131.180-192.168.131.199 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp https https
access-group outside_access_in in interface outside
access-group outside_access_out out interface outside
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group global_access global
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.131.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.131.156-192.168.131.187 inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy mediostvpn internal
group-policy mediostvpn attributes
vpn-tunnel-protocol IPSec
username Anton password jRVOT3qxuT/xdrp5 encrypted privilege 0
username Anton attributes
vpn-group-policy vpn
tunnel-group vpn type remote-access
tunnel-group vpn general-attributes
address-pool pool
default-group-policy vpn
tunnel-group vpn ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:6f543b73d5b1a3c82e794f228364edd0
: end
asdm location sbs 255.255.255.255 inside
541
