11-22-2010 02:17 PM - edited 03-04-2019 10:33 AM
I've ACE and Switch(3560 switch) connected as follow:
ACE(g1/1)<---->(g0/1)Switch. all interfaces appear to be up but still ACE and Switch can't ping each other. Config. is as follow. Please help.
switch#sh ip int b
Vlan1 192.168.10.11 YES manual up up
GigabitEthernet0/1 unassigned YES unset up up
GigabitEthernet0/2 unassigned YES unset down down
GigabitEthernet0/3 unassigned YES unset down down
GigabitEthernet0/4 unassigned YES unset down down
GigabitEthernet0/5 unassigned YES unset down down
GigabitEthernet0/6 unassigned YES unset down down
GigabitEthernet0/7 unassigned YES unset down down
GigabitEthernet0/8 unassigned YES unset down down
GigabitEthernet0/9 unassigned YES unset down down
GigabitEthernet0/10 unassigned YES unset down down
GigabitEthernet0/11 unassigned YES unset down down
GigabitEthernet0/12 unassigned YES unset down down
GigabitEthernet0/13 unassigned YES unset down down
GigabitEthernet0/14 unassigned YES unset down down
GigabitEthernet0/15 unassigned YES unset down down
GigabitEthernet0/16 unassigned YES unset down down
GigabitEthernet0/17 unassigned YES unset down down
GigabitEthernet0/18 unassigned YES unset down down
GigabitEthernet0/19 unassigned YES unset down down
GigabitEthernet0/20 unassigned YES unset down down
GigabitEthernet0/21 unassigned YES unset down down
GigabitEthernet0/22 unassigned YES unset down down
GigabitEthernet0/23 unassigned YES unset down down
GigabitEthernet0/24 unassigned YES unset down down
GigabitEthernet0/25 unassigned YES unset down down
GigabitEthernet0/26 unassigned YES unset down down
GigabitEthernet0/27 unassigned YES unset down down
GigabitEthernet0/28 unassigned YES unset down down
GigabitEthernet0/29 unassigned YES unset down down
GigabitEthernet0/30 unassigned YES unset down down
GigabitEthernet0/31 unassigned YES unset down down
GigabitEthernet0/32 unassigned YES unset down down
GigabitEthernet0/33 unassigned YES unset down down
GigabitEthernet0/34 unassigned YES unset down down
GigabitEthernet0/35 unassigned YES unset down down
GigabitEthernet0/36 unassigned YES unset down down
GigabitEthernet0/37 unassigned YES unset down down
GigabitEthernet0/38 unassigned YES unset down down
GigabitEthernet0/39 unassigned YES unset down down
GigabitEthernet0/40 unassigned YES unset down down
GigabitEthernet0/41 unassigned YES unset down down
GigabitEthernet0/42 unassigned YES unset down down
GigabitEthernet0/43 unassigned YES unset down down
GigabitEthernet0/44 unassigned YES unset down down
GigabitEthernet0/45 unassigned YES unset down down
GigabitEthernet0/46 unassigned YES unset down down
GigabitEthernet0/47 unassigned YES unset down down
GigabitEthernet0/48 unassigned YES unset down down
GigabitEthernet0/49 unassigned YES unset down down
GigabitEthernet0/50 unassigned YES unset down down
GigabitEthernet0/51 unassigned YES unset down down
GigabitEthernet0/52 unassigned YES unset down down
Port-channel1 unassigned YES unset up up
Switch#wr
Building configuration...
[OK]
Switch#sh run
Current configuration : 2382 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport trunk allowed vlan 1,990,1000
switchport mode trunk
interface GigabitEthernet0/1
channel-group 1 mode on
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 192.168.10.11 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
TestACE/Admin# sh run
Generating configuration....
boot system image:c4710ace-mz.A3_2_0.bin
hostname TestACE
interface gigabitEthernet 1/1
channel-group 1
no shutdown
interface gigabitEthernet 1/2
shutdown
interface gigabitEthernet 1/3
shutdown
interface gigabitEthernet 1/4
shutdown
interface port-channel 1
ft-port vlan 1000
no shutdown
access-list ALL line 8 extended permit ip any any
class-map type management match-any remote_access
2 match protocol xml-https any
3 match protocol icmp any
4 match protocol telnet any
5 match protocol ssh any
6 match protocol http any
7 match protocol https any
8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
class remote_access
permit
interface vlan 1000
ip address 192.168.1.10 255.255.255.0
access-group input ALL
service-policy input remote_mgmt_allow_policy
no shutdown
TestACE/Admin# sh ip int b
Interface IP-Address Status Protocol
vlan1000 192.168.1.10 up up
11-23-2010 12:26 AM
The systems you are testing with are in different vlans. This means there is no layer2 path.
They also are in different subnets, this is essentially ok but you need ip routing to work.
The 3560 has no ip address in vlan 1000 and I am also missing the "ip routing" keyword.
Please verify the switch has ip routing enabled and configure ip addresses on all vlans on which you want to enable routing.
You may also need to configure a default gateway on the ACE.
regards,
Leo
